    [Plugin] AreaTextTag
    97 Posts 27 Posters 89.2k Views 27 Watching
      If the chosen font has no superscript 2 '²' it won't be shown.
      What font is used?
      Do you get one with other fonts [use the Settings dialog to adjust various aspects of the AreaText tags] ?
      It might be your Chinese OS ?
      Do you get any error messages in the Ruby Console [I'd expect not, because 3dText simply skips over missing characters in a font's collection].
      If you copy paste this [ 1.23 m²] into the native 3dText tool's pane, for the same font [Arial?] what gets made ? Does the final '²' appear or not ??
      This is what my Arial-Font AreaText tag looks like...
      • guanjinG Offline
        guanjin
        I choose Times New Roman, but the display unit does not
          Have you tried my copy/paste suggestion using the native 3dText tool ?
          • guanjinG Offline
            guanjin
            Paste the local, show normal
              It works fine for our western PCs? 😕
              As a temporary fix...
              Edit the main .rb file inside this tool's subfolder using Notepad.exe.
              Find the 4 occurrences of the text
              .gsub(/2/,"²")
              and change it to read
              .gsub(/2/,"2")
              then you will get
              1.23 m2
              instead of the intended [but failing]
              1.23 m²
              which whilst not perfect it is better.
              If you would prefer
              1.23 m^2
              then change the replacement text
              .gsub(/2/,"2")
              to be
              .gsub(/2/,"^2")
              • guanjinG Offline
                guanjin
                Thank you, of TIG: has been resolved, thanks again!
                  jeff2047
                  got it, thanks share
                    Bokkie
                    hi, was wondering if this plugin will / could, extract or copy an atrribute's value, when inserted into a block with attributes?
                      It reports the area of the face it's 'attached' to.
                      The face/tag need to be in the same context.
                      It doesn't 'report attributes'.
                      There are other tools that do that, but you need to be somewhat clearer in your question...
                      • F Offline
                        ffox
                        Thank you, I am finding all of this really helpful.
                        I searched through the chain and don't think that this has been addressed yet. I am wondering if it is possible to input two text entries per tag. For example, "room #" and "department" both associated with the same square footage, so when exported, you have two text columns per sf which can be sorted accordingly.
                        Thanks in advance!
                          gclyde
                          Would it be possible to select and group a number of faces and give a tag that relates to the total surface area of all selected faces?
                          In addition, would it be possible to produce a similar ruby that totals up the lengths of selected lines/junctions? (not necessarily the perimeter of a face)...this would be icing on the cake for me 😍
                          Graham
                          • atelierpaarA Offline
                            atelierpaar
                            Hello TIG
                            Great script !!
                            Since I am always short in space it would be of great help if it would we possible to have 2-line Text-Tags for instance :
                            Entrance
                            30 m²
                            alignment options
                            • Left
                              Right
                              Center
                              Thanks for looking into it
                              Uli
                              billmorr
                              Hi TIG
                              Firstly, great plug in - thank you for that 😄
                              It seems to crash my SU 2015 (Mac version)when installed alongside Twilight renderer.
                              I have just uninstalled Twilight and everything is cool again.
                              Just thought i'd report the clash in case anyone else has the same problem or if you can fix?
                              Bill
                                billmorr
                                Hi TIG
                                Firstly - great plugin - thank you for this 😄
                                Just discovered on SU 2015 on my Mac, that it crashed SU if Twilight is installed at the same time
                                Don't know if you can fix?
                                  mcmcxlxl
                                  Hi tig,
                                  Thank you for this Tag plugin.
                                  I modified it quite deeply to make it easier.
                                  Could you give me your mail so that i can send it to you.
                                  I would appreciate some critics because i'm not a programmer (but architect) and the way i program is dirty.
                                  Michael
                                    Please use the "Private Message" option here to exchange non-public info...
                                      mcmcxlxl
                                      Sorry
                                      hmm. I have no access to private messages...
                                      Michaël
                                        New members get access to PM-ing after a few valid posts - so try again...
                                          atelierpaar
                                          Hello Tig,
                                          these Area Tex Tags are great - thanks for offering this plugin.
                                          After installing SU 2017 they won`t work anymore and I am in trouble.
                                          Do you have a chance to look into this ?
                                          Thanks already
                                          Ulrich
                                            The error in the Ruby Console tells the story.
                                            Unfortunately v2017 looses earlier references set to the contents of a group, e.g. when it's exploded, so the code fails, I'm currently fixing this weirdness in my ExtrudeTools...
                                            However, it might be some other Ruby2.2 foible...
                                            I'll look into this tool asap...
                                            • 4 / 5
