SketchUp 8 + Vray Crashing !!!
Hi.
I'm using Sketchup ver. 8 + Vray ver. 1.48.93
At first I had no problems whatsoever. But when my models got more complex (I think) sketchup started randomly crashing, bugsplat message started appearing, sometimes it renders 1-2 images and the crashes, sometimes it crashes right away, sometimes it doesn't crash or freeze - just doesn't do enything when I press the render button.My system specs are: Core i7 4.5Ghz (slightly overclocked), 8GB RAM, Nvidia Gigabyte GTX 560 ti, ... - so the PC should not be the problem...
If someone is experiencing the same problems as I am or just has a suggestion what I might do is VERY welcome to reply!
10X A LOT IN ADVANCE!!!
can you update to 1.49.01 and see if you still have the same problems?
I was thinking about it... I'll try.
So far I tried rendering in SU ver.6 and I think it's more stable but the problem still occurs.
I was wondering whether the video card has something to do with it? -
The strange thing is that it renders fine once and tghe next time I get the bugsplat error...
And the scene is just 22MB.
I tried also rendering a 60MB~ scene and it completely rejected rendering it :S - just nothing happened. -
When you experience problems with an application, always check if you have the latest version. It might very likely be that your problem is fixed in the latest version.
Agreed. I have been using 1.49.01 since its release last year and I have never had a Bugsplat. Knock on wood.
Register LoginAdvertisement
