    SketchUp 8 + Vray Crashing !!!
    renderpluginsextensions
    6 Posts 4 Posters 2.8k Views 4 Watching
      thund3r
      Hi.
      I'm using Sketchup ver. 8 + Vray ver. 1.48.93
      At first I had no problems whatsoever. But when my models got more complex (I think) sketchup started randomly crashing, bugsplat message started appearing, sometimes it renders 1-2 images and the crashes, sometimes it crashes right away, sometimes it doesn't crash or freeze - just doesn't do enything when I press the render button.
      My system specs are: Core i7 4.5Ghz (slightly overclocked), 8GB RAM, Nvidia Gigabyte GTX 560 ti, ... - so the PC should not be the problem...
      If someone is experiencing the same problems as I am or just has a suggestion what I might do is VERY welcome to reply!
      10X A LOT IN ADVANCE!!!
      • andybotA Offline
        andybot
        can you update to 1.49.01 and see if you still have the same problems?
          thund3r
          I was thinking about it... I'll try.
          So far I tried rendering in SU ver.6 and I think it's more stable but the problem still occurs.
          I was wondering whether the video card has something to do with it?
            thund3r
            The strange thing is that it renders fine once and tghe next time I get the bugsplat error...
            And the scene is just 22MB.
            I tried also rendering a 60MB~ scene and it completely rejected rendering it :S - just nothing happened.
              When you experience problems with an application, always check if you have the latest version. It might very likely be that your problem is fixed in the latest version.
              • V Offline
                valerostudio
                Agreed. I have been using 1.49.01 since its release last year and I have never had a Bugsplat. Knock on wood.
