    How to determine the lenght of an arc
    7 Posts 5 Posters 658 Views 5 Watching
      brandy20
      I'd like to draw an arc of a predetermined lenght. Is there a simple way or a plugin to get it quickly without doing math every time?
      Thanks,
      Luca
        mac1
        Thanks,
        Luca
        I doubt it since there are an infinite number of arcs you can draw at a predetermined length. Remember you need both the angle and radius. ❓
          Well, the native SU arc tool allows specifying the chord length, the segment count and the bulge or radius but not the arc length.
          Knowing the chord however, you could define (mathematically) an arc length, too so I guess it could be done with ruby (but please, do not ask mehow)
            Try this ArcByTools script http://forums.sketchucation.com/viewtopic.php?p=365402#p365402
            It draws arcs of a specified radius/length/segments - calculating the swept-angle
            or of a specified swept-angle/length/segments - calculating the radius.
              brandy20
              Yes, that's what I meant
              @TIG: Thank you TIG, that's a useful plugin for me.
              Luca
              • simon le bonS Offline
                simon le bon
                I have to test this new Tig's tool which seems perfect for the purpose.
                I just wanted to remind and connect readers with the same request I had in times and which can complete the purpose: Can i draw an arc with a specifying circumference value
                And especially to focus on a calculator linked by Pilou
                (clic the picture)
                http://forums.sketchucation.com/download/file.php?id=7096&mode=view
                😉 simon
                  brandy20
                  Hi Simon,
                  Thank you for this hint, it will be very useful, too! 👍
                  Luca
