    Strange effect....could it be fixed?
    12 Posts 6 Posters 607 Views 6 Watching
    • tibetT Offline
      tibet
      hi,
      i´ve encountered some strange effect during creating stainless stairs with curviloft plugin.
      any ideas?
      thanks a lot for passing by
      best of luck!
      http://i44.tinypic.com/eg2w08.jpg
      http://i52.tinypic.com/zujcp1.jpg
      stairs.skp
      SU 2015 Pro on Win10 x64
        Frankly I can't see why you need a plugin at all... 😕
        Make a wooden 'tread' component and one metal 'riser' component - hide its mitered ends edges so when it meets the next one it is seamless.
        Use Move+Ctrl to copy the preselected treads+riser up/cross, xNN to make multiple copies.
        Make the top/bottom metal 'risers' unique and adjust them to suit their location...
        Copy the metal 'riser' to both sides of the tread.
        Done.
        This is a more general and flexible approach. 🤓
          What's the strange effect? I don't see anything to be fixed. I would build the stairs as TIG indicated, though.
          • jeff hammondJ Offline
            jeff hammond
            i imagine the softened edges is what he's talking about (those are tubes.. not pipes)
            select the group then go window->soften edges (or right-click the selection and choose soften/smooth edges)
            adjust the slider accordingly (default 30º works well)
            dotdotdot
            • V Offline
              Vicspa
              Take smoothing off, and they will be square.
              stairs.skp
              • pbacotP Offline
                @tibet said:
                hi,
                any ideas?
                best of luck!
                I guess I am curious how curviloft can be of use here?
                  George, I'm curious. If you were building these steps for real, how would you construct the stringers? Would stairs as you show them be structurally sound?
                  thinking about how they would be constructed in reality can be useful in determining how to draw them in SU.
                  • pbacotP Offline
                    Actually I might find a neat method. I just didn't know. The smoothing was solved pretty easily so.. you may have something useful. Didn't mean to be over-critical.
                    Follow-me might do it too.
                    • tibetT Offline
                      tibet
                      hi dave,
                      thanks for your suggestion, you´re right.
                      i ´ve seen, how the stringers are made, but i need more time with SU to realize it´s power & geniality.
                      hope to find out with this great forum and you guys soon 😄
                      regards!
                      • tibetT Offline
                        tibet
                        just getting accustomed with different tools to SU (even i have to face criticism from cad/solid users:-(
                        http://i56.tinypic.com/qxqdub.jpg
                        • tibetT Offline
                          tibet
                          hi jeff and victor,
                          thank you for the missing piece of my puzzle
                          Sharing your valuable experiences is very much appreciated
                          glad to have you around guys !
                          very best wishes!
                          • tibetT Offline
                            tibet
                            hi,
                            thanks to all for valuable tips and ideas!
                            best of luck !
                            note: the metal riser looks like round one, but it´s actually square.
