    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 31.2k Views 16 Watching
    • AdamBA Offline
      AdamB
      @thomthom said:
      I take it that the OS Ruby versions is much newer now - and Iยดd have to link the build to something other than the OS Ruby?
      No, a Plugin resolves the symbols on load.
      @thomthom said:
      Also, when compiling a C Extension under Mountain Lion - how backwards compatible will it be?
      As much as you ask for it to be: eg -mmacosx-version-min=10.4 will ensure it runs on 10.4 and up.
      @thomthom said:
      I should add some warning about the -Ox flag that it might cause problems - since it's very aggressive optimization.
      Just to correct this. The optimization does not produce 'wrong code' per se. Its that it commonly will remove leaf function stack frames to increase performance, meaning Ruby's GC can't find a reference to a Object and it gets marked for collection. So ensure you keep references and you'll be fine.
        Really? But if the OS Ruby is 1.9, and I compile without doing anything. Won't it be compiled for 1.9 only then? Isn't there completely different functions between 1.8 and 1.9?
        Where does this flag go in the compile process? In the MAKEFILE? In the arguments of the make command?
        (I'm very green to this.)
        Thanks for the clarification.
          @designingcrime said:
          Hey guys, so I finally got a Ruby C extension to compile on both os x and windows and link curllib. I got a lot of help from Luis at the RubyInstaller group and ended up using RubyInstaller and DevKit to link curl and build using the gcc compiler included with devkit.
          Here is the extension. Its a modified version of Dana's sketchup downloader, but also included uploading, basic http authentication and ssl certificate checking(all through curl). I provided instructions on how to build on both os x and windows.
          https://github.com/sunglass/SunglassPlugins/tree/master/SG-SketchupHook/src/Connection%20Manager
          Thanks for all your help guys.
          Dana - Lets get your Sketchup downloader plugin working.
          Link is dead. ๐Ÿ˜ž
          • W Offline
            Whaat
            Just wanted to thank Thomas and everyone else for the contributions in this thread. I tried to get Thomas' Hello World extension working and had no problems at all, thanks to his clear documentation.
            My next experiment will be to incorporate SketchUp SDK calls into the Ruby Extension. Has anyone done this? Is it relatively straightforward? Any 'gotchas' that you could warn me about? Thanks
            • W Offline
              Whaat
              Problems already...
              I have the SDK .h files installed in the same folder as 'SX_HelloWorld.c'. I'm not sure what to do with the binary files provided with the SDK.
              I tried to include just one header <slapi/model/model.h> file from the SDK and this was the result.
              Feeling clueless...
              • tt_suT Offline
                tt_su
                We're actually working on a Hello World example for Visual Studio and Xcode for compiling Ruby C/C++ Extensions for SketchUp. We can expand that (create a work or extra branch) with SLAPI configured as well.
                By the way can you post a Gist of your code? You got some syntax errors there that appear to not be related to linking to the correct headers.
                • W Offline
                  Whaat
                  Interesting, I was just now doing some research into 'extconf.rb' and I'm starting to think my problem is related to not configuring the location of the .lib and .h files inside of 'extconf.rb' using the 'dir_config' and 'have_library' commands.
                  BTW, the only difference between my code and your 'hello world' code on bitbucket is that I #included one the SLAPI .h files at the top.
                  I had assumed (or hoped) that it would be properly linked since I put the files in the same location as the .c file that I was trying to compile. ๐Ÿ‘Š
                  It goes without saying that I am a complete noob at this.
                  • tt_suT Offline
                    tt_su
                    Hi Dale
                    I looked into this and found that you cannot use Visual Studio's nmake for this as it's C89 - and the SLAPI is written in C99.
                    It would work if you install the DevKit at Ruby Windows Installer - though I'm still working out some minor quirks. We're preparing some Hello World examples to get started with Ruby C Extensions. Can you hang in there a little bit more?
                    • W Offline
                      Whaat
                      @tt_su said:
                      Hi Dale
                      No problem. Thanks for looking into this. I am excited to see the new examples... ๐ŸŽ‰
                      • tt_suT Offline
                        tt_su
                        Good news is that I got the SLAPI example compiling under OSX. I need to test on Windows and clean up the extconf.rb file a little.
                        • W Offline
                          Whaat
                          Cool! ๐Ÿ‘
                            tomasz
                            It will be very good indeed to have those examples easy to compile and ready to expand.
                            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                              cncmachineguy
                              Hello All,
                              I am just starting on C extensions for SU and have a quick question. I have been successful following Thom's hello world example on bit bucket. My first question is are there any known IDE solutions to compile from? I don't relish the idea of writing code in notepad++ or other, then compiling from command line, then loading into SU and hoping it works.
                              Is this the way this is being done now or have I missed something?
                              In any event, THANK you all for the hard work you have put into this so far, if this is the best known solution, I will follow it.
                              BTW, working within Win7(64)
                              • tt_suT Offline
                                tt_su
                                We are setting up a C++ Hello World example for Visual Studio and Xcode. That will give you better environments to work and debug in.
                                  cncmachineguy
                                  Thanks Thomas, I offer to do testing if you need it. Otherwise I will keep my eye on this.
                                    cncmachineguy
                                    Not allowed to PM yet, but email has been sent
                                    • 6
                                    • 7
                                    • 8
                                    • 9
                                    • 9 / 9
