    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 46.3k Views 16 Watching
    • W Offline
      Whaat
      Problems already...
      I have the SDK .h files installed in the same folder as 'SX_HelloWorld.c'. I'm not sure what to do with the binary files provided with the SDK.
      I tried to include just one header <slapi/model/model.h> file from the SDK and this was the result.
      Feeling clueless...
      • tt_suT Offline
        tt_su
        We're actually working on a Hello World example for Visual Studio and Xcode for compiling Ruby C/C++ Extensions for SketchUp. We can expand that (create a work or extra branch) with SLAPI configured as well.
        By the way can you post a Gist of your code? You got some syntax errors there that appear to not be related to linking to the correct headers.
        • W Offline
          Whaat
          Interesting, I was just now doing some research into 'extconf.rb' and I'm starting to think my problem is related to not configuring the location of the .lib and .h files inside of 'extconf.rb' using the 'dir_config' and 'have_library' commands.
          BTW, the only difference between my code and your 'hello world' code on bitbucket is that I #included one the SLAPI .h files at the top.
          I had assumed (or hoped) that it would be properly linked since I put the files in the same location as the .c file that I was trying to compile. πŸ‘Š
          It goes without saying that I am a complete noob at this.
          • tt_suT Offline
            tt_su
            Hi Dale
            I looked into this and found that you cannot use Visual Studio's nmake for this as it's C89 - and the SLAPI is written in C99.
            It would work if you install the DevKit at Ruby Windows Installer - though I'm still working out some minor quirks. We're preparing some Hello World examples to get started with Ruby C Extensions. Can you hang in there a little bit more?
            • W Offline
              Whaat
              @tt_su said:
              Hi Dale
              No problem. Thanks for looking into this. I am excited to see the new examples... πŸŽ‰
              • tt_suT Offline
                tt_su
                Good news is that I got the SLAPI example compiling under OSX. I need to test on Windows and clean up the extconf.rb file a little.
                • W Offline
                  Whaat
                  Cool! πŸ‘
                    tomasz
                    It will be very good indeed to have those examples easy to compile and ready to expand.
                      cncmachineguy
                      Hello All,
                      I am just starting on C extensions for SU and have a quick question. I have been successful following Thom's hello world example on bit bucket. My first question is are there any known IDE solutions to compile from? I don't relish the idea of writing code in notepad++ or other, then compiling from command line, then loading into SU and hoping it works.
                      Is this the way this is being done now or have I missed something?
                      In any event, THANK you all for the hard work you have put into this so far, if this is the best known solution, I will follow it.
                      BTW, working within Win7(64)
                      • tt_suT Offline
                        tt_su
                        We are setting up a C++ Hello World example for Visual Studio and Xcode. That will give you better environments to work and debug in.
                          cncmachineguy
                          Thanks Thomas, I offer to do testing if you need it. Otherwise I will keep my eye on this.
                            cncmachineguy
                            Not allowed to PM yet, but email has been sent
                            • 9 / 9
