    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
    • W
      Whaat
      @tt_su said:
      We're actually working on a Hello World example for Visual Studio and Xcode for compiling Ruby C/C++ Extensions for SketchUp. We can expand that (create a work or extra branch) with SLAPI configured as well.
      By the way can you post a Gist of your code? You got some syntax errors there that appear to not be related to linking to the correct headers.
      Interesting, I was just now doing some research into 'extconf.rb' and I'm starting to think my problem is related to not configuring the location of the .lib and .h files inside of 'extconf.rb' using the 'dir_config' and 'have_library' commands.
      BTW, the only difference between my code and your 'hello world' code on bitbucket is that I #included one the SLAPI .h files at the top.
      I had assumed (or hoped) that it would be properly linked since I put the files in the same location as the .c file that I was trying to compile. πŸ‘Š
      It goes without saying that I am a complete noob at this.
      • tt_suT
        tt_su
        Hi Dale
        I looked into this and found that you cannot use Visual Studio's nmake for this as it's C89 - and the SLAPI is written in C99.
        It would work if you install the DevKit at Ruby Windows Installer - though I'm still working out some minor quirks. We're preparing some Hello World examples to get started with Ruby C Extensions. Can you hang in there a little bit more?
        • W
          Whaat
          @tt_su said:
          Hi Dale
          No problem. Thanks for looking into this. I am excited to see the new examples... πŸŽ‰
          • tt_suT
            tt_su
            Good news is that I got the SLAPI example compiling under OSX. I need to test on Windows and clean up the extconf.rb file a little.
            • W
              Whaat
              Cool! πŸ‘
              • T
                tomasz
                It will be very good indeed to have those examples easy to compile and ready to expand.
                • C
                  cncmachineguy
                  Hello All,
                  I am just starting on C extensions for SU and have a quick question. I have been successful following Thom's hello world example on bit bucket. My first question is are there any known IDE solutions to compile from? I don't relish the idea of writing code in notepad++ or other, then compiling from command line, then loading into SU and hoping it works.
                  Is this the way this is being done now or have I missed something?
                  In any event, THANK you all for the hard work you have put into this so far, if this is the best known solution, I will follow it.
                  BTW, working within Win7(64)
                  • tt_suT
                    tt_su
                    We are setting up a C++ Hello World example for Visual Studio and Xcode. That will give you better environments to work and debug in.
                    • C
                      cncmachineguy
                      Thanks Thomas, I offer to do testing if you need it. Otherwise I will keep my eye on this.
                      • C
                        cncmachineguy
                        Not allowed to PM yet, but email has been sent
                        • 9 / 9
