    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 105.0k Views 35 Watching
      taro824
      Thank you for the Great plug-in but I'm having a problems.
      I got the message from the Ruby console
      Error #<NoMethodError:undefined method putsv' for #<File:0x1ed5eecc>.> C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:643:in run_shell_command'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in open' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in run_shell_command'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:465:in execute' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:290:in initialize'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in new' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in process'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:164:in options_dialog' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in call'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in show_modal' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in options_dialog'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:128:in `run'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:101
      quietly_force_sync_mats_cb just called
      Did I missed something when I installed the plugin ?
        There is a simple typo in the code - probably 'v' was pressed instead of 'ctrl+v' to paste.
        The original author Andreas needs to correct it...
        In the meanwhile you can correct it yourself in your copy...
        Open the file 'ImageMagick.rb' in the 'ae_TextureResizer' subfolder in your Plugins folder, using Notepad.exe and look for the text saying:
        f.putsv%[cd "#{@cache_dir}"]
        around line #643.
        Change it to read:
        f.puts %[cd "#{@cache_dir}"]
        I.E. replace the 'v' at the end of the 'puts' with a <space>.
        Save the file.
        Restart SketchUp and retest, it should now work... 😄
          taro824
          Hi TIG,
          Thank you for the replying so soon and the solution 😄
            The author Andreas has now updated the file.
            You can download the latest version from the first post in this thread, or Auto-Install it from the Plugins Store shortly...
            • OxerO Offline
              Oxer
              On Mac the new version (1.5.1) gives a Ruby Console Error:
              %(#BF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/TextureResizer.rb
              no such file to load -- /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/Bounds.rbError al cargar archivo ae_TextureResizer.rb
              no such file to load -- /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/Bounds.rb]
              I seen into the ae_TextureResizer folder, and Bounds.rb file doesn't exist.
              http://www.oxervision.blogspot.com/
                Aerilius
                There is no use for that file in the Sips version, so the require line shouldn't be there. I fixed it.
                  Aerilius
                  A small update to improve the webdialog when using higher dpi settings.
                    lopangkar
                    Really thanks for your great work.
                      T.W.
                      I'm getting a script error. Can someone help?
                      OS:Win 7 home premium ser. pk. 1
                      Intel I3 processer.
                      Latest ver Sketchup
                      Don't know what else you made need.
                      http://i.imgur.com/76Uhs2l.jpg
                        Aerilius
                        Can you try the attached version?
                        ae_TextureResizer_1_5_7.rbz
                        • bobpineoB Offline
                          bobpineo
                          I'm having some trouble running the plugin, that looks very cool I might add!
                          This might be something outside the workings of your plugin, as I sometimes get this message with other plugins...
                          thank you in advance for your help!
                          Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                            JeremyNOLA
                            is it normal for this to take an extended amount of time to execute? I have been watching it process on a 30mb file for about 20 minutes. I check the activity monitor and SU is still performing and using resources so I know it's doing SOMETHING...let me know. thanks!
                              AirWindSolar
                              Did it finish yet?
                              • OxerO Offline
                                Oxer
                                The plugin (OS X version) work fine and very quick on Mac OSX & SU2013 but on SU2014 the processing is very long and sometimes SU crash.
                                • brodieB Offline
                                  brodie
                                  This doesn't seem to be working for me with 2015. Is it just me?
                                    Aerilius
                                    Sorry, I was away the last week. I tested it in SU 2015 and it seems to be still working.
                                    It requires ImageMagick to be installed (the plugin is just a UI and calculates the command for ImageMagick).
                                    • Do you have ImageMagick installed? If it was not, the plugin should prompt.
                                    • Is it possible the plugin does not find ImageMagick? Can you give me the results from the Ruby Console of:
                                    AE;;TextureResizer;;ImageMagick.installed?
                                    AE;;TextureResizer;;ImageMagick.class_variable_get(;@@install_location)
                                    Sketchup.read_default("ImageMagick","location")
                                    • F Offline
                                      faust07
                                      Plugin works great in SU 2016 - a handy time and file size saver. Thanks!
                                      • P Offline
                                        Pherim
                                        It doesn't work in SU2016 for me... I click apply and it just clears all parameters. There is nothing in the ruby console and I do have ImageMagick installed.
                                        • P Offline
                                          Pherim
                                          Turns out I did not have the latest version installed because the extension warehouse still has 1.5.5. Now it just says "Processing" when I click "apply", but seems not to do anything if nothing is selected, whereas it creates resized versions of textures in a selection although it does not replaces the original ones but just adds a 0 to their names. It works in Sketchup 8, though. Could it be a conflict with another plugin?
                                          edit: It works on my laptop... so I guess I need to figure out the difference between these two installations to find out why it's not working on my PC.
                                          • P Offline
                                            Pherim
                                            Me again... so far I found out that it appears not to be working when Make Fur by Tak2hata is also installed... however, only on my PC (Windows 7 64bit) in SU2016. With SU8 and on my laptop (also SU2016) it works! Any ideas?
                                            • 6
                                            • 5 / 6
