    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 111.1k Views 35 Watching
      Aerilius
      I published the new version 1.4.5
        Aerilius
        Small update (1.4.7):
        • added icon
        • OxerO
          Oxer
          I can't see the icon in Mac OSX 10.8.2, the plugin (1.4.7) works fine only the icon problem. Non Ruby console Error.
            Aerilius
            Menus don't have icons. The plugin doesn't include a (one button) toolbar, but an icon is the pre-condition for any future toolbars 😉
            • OxerO
              Oxer
              I have added one line to the TextureResizer. rb and now i can see the icon plugin. This is the line:
              "UI::Toolbar.new(@@translate["Resize Textures").add_item(cmd_resize)]"
              This line go after this line: " UI.menu("Plugins").add_item(cmd_resize)"
              Thanks for the icons!!
              PS: The plugin works fine, when you push the icon, it appears the plugin's window. 👍
              • P
                paolo
                I should be missing something cause I have got make Unique Texture++ and Texture Resizer, the last one is not doing anything.
                I have been using Goldilocks v2.0 to help me notice what textures to are too big on view.
                Could some one tell me whats wrong with Texture Resizer? there is any other plugin? how can I choose better texture size?
                Thx
                • T
                  taro824
                  Thank you for the Great plug-in but I'm having a problems.
                  I got the message from the Ruby console
                  Error #<NoMethodError:undefined method putsv' for #<File:0x1ed5eecc>.> C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:643:in run_shell_command'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in open' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in run_shell_command'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:465:in execute' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:290:in initialize'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in new' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in process'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:164:in options_dialog' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in call'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in show_modal' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in options_dialog'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:128:in `run'
                  C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:101
                  quietly_force_sync_mats_cb just called
                  Did I missed something when I installed the plugin ?
                    There is a simple typo in the code - probably 'v' was pressed instead of 'ctrl+v' to paste.
                    The original author Andreas needs to correct it...
                    In the meanwhile you can correct it yourself in your copy...
                    Open the file 'ImageMagick.rb' in the 'ae_TextureResizer' subfolder in your Plugins folder, using Notepad.exe and look for the text saying:
                    f.putsv%[cd "#{@cache_dir}"]
                    around line #643.
                    Change it to read:
                    f.puts %[cd "#{@cache_dir}"]
                    I.E. replace the 'v' at the end of the 'puts' with a <space>.
                    Save the file.
                    Restart SketchUp and retest, it should now work... 😄
                    • T
                      taro824
                      Hi TIG,
                      Thank you for the replying so soon and the solution 😄
                        The author Andreas has now updated the file.
                        You can download the latest version from the first post in this thread, or Auto-Install it from the Plugins Store shortly...
                        • OxerO
                          Oxer
                          On Mac the new version (1.5.1) gives a Ruby Console Error:
                          %(#BF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/TextureResizer.rb
                          no such file to load -- /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/Bounds.rbError al cargar archivo ae_TextureResizer.rb
                          no such file to load -- /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ae_TextureResizer/Bounds.rb]
                          I seen into the ae_TextureResizer folder, and Bounds.rb file doesn't exist.
                            Aerilius
                            There is no use for that file in the Sips version, so the require line shouldn't be there. I fixed it.
                              Aerilius
                              A small update to improve the webdialog when using higher dpi settings.
                              • L
                                lopangkar
                                Really thanks for your great work.
                                • T
                                  T.W.
                                  I'm getting a script error. Can someone help?
                                  OS:Win 7 home premium ser. pk. 1
                                  Intel I3 processer.
                                  Latest ver Sketchup
                                  Don't know what else you made need.
                                  http://i.imgur.com/76Uhs2l.jpg
                                    Aerilius
                                    Can you try the attached version?
                                    ae_TextureResizer_1_5_7.rbz
                                    • bobpineoB
                                      bobpineo
                                      I'm having some trouble running the plugin, that looks very cool I might add!
                                      This might be something outside the workings of your plugin, as I sometimes get this message with other plugins...
                                      thank you in advance for your help!
                                      Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                        JeremyNOLA
                                        is it normal for this to take an extended amount of time to execute? I have been watching it process on a 30mb file for about 20 minutes. I check the activity monitor and SU is still performing and using resources so I know it's doing SOMETHING...let me know. thanks!
                                          AirWindSolar
                                          Did it finish yet?
                                          • OxerO
                                            Oxer
                                            The plugin (OS X version) work fine and very quick on Mac OSX & SU2013 but on SU2014 the processing is very long and sometimes SU crash.
                                            • 5 / 6
