    [plugin] Clip or Trim Terrain Mesh (Update)
    38 Posts 18 Posters 59.4k Views 18 Watching
      dinkdesign
      You guys are absolute legends. You take modeling to a whole new level.
      I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
      Special thanx to Gaieus and ThomThom for their constant useful contributions.
        Well, I really had to approve this post (even though I have not contributed with anything in this topic). πŸ˜‰
          Ben Ritter
          Sam, thank you for sharing your efforts.
          • utilerU Offline
            utiler
            Hi Sam, during your tutorial video at about 1:20 you say, 'If its only zoomed out 3 or 4 clicks....'
            What are you referring too here?
            πŸ‘
            Just Curious...
            • sdmitchS Offline
              sdmitch
              I viewed the tutorial and I don't hear what you heard but I would assume that I am referring to zooming out from the smallest possible patch 3 or 4 clicks.
              http://sdmitch.blogspot.com/
              • utilerU Offline
                utiler
                Thanks for the reply, Sam.
                At about 1min 20sec you refer to 'if its only zoomed out 3 or 4 clicks [no more than that] the grid of the two patches match....'
                Are you referring to zooming in Google Earth:
                πŸ‘
                Just Curious...
                • sdmitchS Offline
                  sdmitch
                  Yes, the Google Earth get location zoom. I thought you were talking about the clip and trim plugin not the add skirt.
                  • utilerU Offline
                    utiler
                    My bad, Sam. I can see how you would have been ill informed.... 😳
                    Thank you. πŸ‘
                    Just Curious...
                    • G Offline
                      greatcurve
                      Is there a way to make these plugins work with SU 8?
                        Are you getting errors?
                        The author uses SU8 - as his profile says - and usually if a plugin doesn't work with a version it's explicitly stated in the plugin description. I believe this should work with SU8.
                          Works fine in v8
                          • G Offline
                            greatcurve
                            Sorry. I'm learning to use google/SU terrain tools as they are quite handy for making large terrains as opposed to Max.
                            Gaieus helped me out on the Lumion forum and I was able to get everything going.
                            • G Offline
                              Gammafield
                              This is amazingly fantastic - biiig thanx.
                                JGA
                                sdmitch,
                                Thanks for sharing the terrain skirt plugin.
                                Regards,
                                JGA
                                  MLUY
                                  Hello Experts,
                                  When I use this plugin it tells me to select a Google Terrain patch
                                  I have a trianglar mesh terrain file which is very big
                                  How can I add a skirt and also add a bottom make it into a solid?
                                  I have tried TIG's jointpush and pull tool, but I only manage to do the skirt and
                                  cannot manage to get a solid. (Unless manually....but thats too much work)
                                  Michiel
                                  • sdmitchS Offline
                                    sdmitch
                                    @mluy said:
                                    Hello Experts,
                                    Michiel
                                    The Add Terrain Skirt plugin on my blog page does not require the mesh to be a Google Earth Terrain.
                                    • K Offline
                                      kiwi15
                                      • So why don't you post the improved plugin (that does not require the mesh to be a Google Earth Terrain) here at Sketchucation?
                                      It is a bit easier for people to install it using the Sketchucation Extension Store directly from within SU.
                                      • sdmitchS Offline
                                        sdmitch
                                        Because I don't want to?
                                        Download from the blog. Send to a compressed folder. change extension from zip to rbz. Install as usual.
                                        • 2 / 2
