    "Drilling" a hole in a rod ?
    6 Posts 4 Posters 649 Views 4 Watching
    • J
      jacktar
      Hi again out there.
      I have run into a problem that I hope somebody out there can help me with.
      I wil try to make a simple example of the problem:
      Lets say Imake round rod ( 15mm thick and 100mm long) Then I want to "insert" another rod that is 6mm thick through the first rod ( drill a hole trough the first rod to form a T handle)
      When I try to do this by using "drawing a cirkle" + Push/pull, then I get the message: "Cannot push/pull curved or smoothed surfaces"
      How do I fix this problem?
      Best regards
      • BoxB
        There are quite a few answers to this, but the most simple one is,
        Draw your second circle so it isn't touching the rod, then it will push/pull.
        • D
          devilreborn
          Draw a circle perpendicular to the first rod, push the circle until it intersects with your first rod
          Use intersect with model if necessary ( to create lines around the part where the 2 rods intersect ) but that's up to you πŸ˜‰
          If I got what you're saying then this should work
          • TIGT
            Very tiny geometry causes problem for Sketchup and OpenGL so you are getting near the limit here...
            Scale everything up x10 before doing the intersect, scale back down afterwards...
            • J
              jacktar
              Thank you for cind help to all of you. πŸ˜„
              Best regards
              jacktar
              • J
                jacktar
                Here's a simple step-by-step...[attachment=0:2d9t1ibc]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2d9t1ibc]
                Thank you so much TIG.
                The "drawing" wasa great help πŸ˜„
                Best regards from
                jacktar
