    Shortcut key for explode?
    28 Posts 8 Posters 9.6k Views 8 Watching
    • C
      CalypsoArt
      I'd like to set up a short key, E, for "explode." Cant find explode in the command list. Anyone?
      • TIGT
        Select something that can be 'Exploded' - i.e. a Group or a Component-Instance - check the option appears in the context-menu.
        Then leaving it selected... activate Window > Preferences > Shortcuts, and Filter for 'Explode'...
        Click it.
        Make a Shortcut for it.
        If you want to 'Explode' a Curve [or an Image] select one and then set another shortcut key-combo for that too.
        Tip: DON'T use a plain 'X' UNLESS you instinctively make Move/Rotate Array-Copies using 10x or 10 or 10 - because pressing X10 will look for eXplode and confuse you !!
        I use Shift+X for eXplode, and Shift+Alt+X for eXplode-curve [and for the rarer Explode-Image I use the context-menu]...
        The 'E' is pre-assigned to the Erase Tool - so perhaps assigning Shift+E for Explode would be better ???
        • S
          Scozzarella
          I use Mac OS X and can't assign a Shortcut to Explode.
          I select a group and go to Preferences and Assign a Shortcut but it doesn't work.
          If I click right button I can see Explode option and it works.
          • TIGT
            On a MAC some key presses and/or combos are preserved for system use.
            Try another key ??
            • S
              Scozzarella
              I tried a lot of keys, but nothing to do.
              Could someone use Mac give me an advice, please?
              • TIGT
                What keys are failing ?
                On a MAC you can't combine them with some 'modifier' keys... which are system-reserved...
                You need to give us some clues as otherwise we are guessing.
                • S
                  Scozzarella
                  Thank you.
                  I tried all single key and all shift or control combinations, but they don't work.
                  Do you have a Mac or a friend with a Mac?
                    You aren't pressing Enter after typing the key stroke you want to set are you?
                    • S
                      Scozzarella
                      No, I don't press Enter. From the Keyboard I hit a key and then close the window.
                      • R
                        rv1974
                        it's a windowless command. Are you sure you use Sketchup?
                        • S
                          Scozzarella
                          Of course, Sketchup for Mac
                          • R
                            rv1974
                            What window do you close? There are no windows accomponing explode command
                            • Gus RG
                              Gus R
                              Something is buggy with the shortcuts in preferences because I can sometimes search for "explode" and find it and apply a shortcut and then when I restart SU it can't find "explode." Scrolling to Edit/Item/Explode will show up sporadically.
                              Make sure you click the "+" sign to the right of the shortcut and then click OK.
                              www.instagram.com/gusrobatto/
                              www.facebook.com/gusrobatto
                              • BoxB
                                As mentioned above You must have something explodable selected for the native explode to appear in the shortcuts.
                                • BoxB
                                  I'll just add this to help people understand that the shortcuts list in preferences is context specific.
                                  You can see when I filter by edit with nothing in the model selected the list is quite short but when I select a simple group the list of possible shortcuts grows considerably.
                                  • S
                                    Scozzarella
                                    Thank you but I select a group and in the list the explode appears. In Mac version there isn't + button.
                                    When I select the command on the shortcut list and assign a shortcut, then close, the shortcut doesn't work.
                                    • BoxB
                                      Sorry, my comments were not really addressed to you Scozzarella, they were more of a general thing because people often get confused by the contextual shortcuts.
                                      Your issue is something else and as I'm not a Mac user I can add nothing more than has already been said.
                                        What is the shortcut you are trying to assign?
                                        • S
                                          Scozzarella
                                          I tried a lot of keys.
                                            We're trying to help here. Could you be specific?
                                            Have you actually installed SketchUp or are you running it from the .dmg?
                                            • 1 / 2
