    Dojo
    42 Posts 20 Posters 2.3k Views 20 Watching
    • artysmediaA Offline
      artysmedia
      @nomeradona said:
      keep on playing because when you play we see the best from you.
      This quote is useful for all us! 👍
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
      • soloS Offline
        solo
        http://img5.imageshack.us/img5/8885/backatdojo.jpg
        http://www.solos-art.com
        • Rich O BrienR Online
          FilterForge?
          Nice 👍
          • soloS Offline
            solo
            FilterForge?
            Nice 👍
            No, Postworkshop
            澳门原料网-资料免费精选
            澳门原料网提供网络澳门原料网高清在线游戏的APP,澳门原料网满足用户新视觉在线游戏体验,更多精彩游戏尽在澳门原料网,带给您不一样的游戏体验!
            (postworkshop.net)
              FotoSketcher on steroids... or Photoshop without the confusion 👍
                japc
                Hi Solo!
                Very nice renders you have here.
                Just have a little doubt about the ground texture in the first picture. I think that, a little less reflection on the wood floor sould improve the ambience.
                http://www.arquitecturas-paralelas.pt
                  artysmedia
                  Jajajaja But it is half part of the fight! 😆
                  Good idea to make a simple Potosop
                  Blog: Artysmedia
                    sepo
                    Lighting is sublime...like it a lot.
                    • AdamBA Offline
                      AdamB
                      Beautiful. You really are getting the hang of this modelling thing, aren't you. ☀
                      Pete, what does Glare actually do? Its a blending function, or a lighting function?
                        sepo
                        Glare is related to lighting .... but in Thea it is postprocess.
                        • soloS Offline
                          solo
                          Adam,
                          I guess the best way to describe it would be as a post render lighting effect in Thea, you have two options, first there is the Radial which is very like a bloom effect and the other is the Blade method which is like light flare effect, both are very customisable with parameters to set amount and size.
                            • soloS Offline
                              solo
                              Here is an example of the glare radial effect.
                              SU model:
                              http://img442.imageshack.us/img442/8811/toothbrushinglasliness.jpg
                              Straight Thea render, no glare:
                              http://img256.imageshack.us/img256/8863/toothbrushinglas.jpg
                              With 4% radius glare 20% Weight:
                              http://img199.imageshack.us/img199/7639/toothbrushglasglares.jpg
                              • numbthumbN Offline
                                numbthumb
                                Somehow I missed this. But it doesn´t change the fact that I enjoy every look of it. Plus I´ve learned something new today 👍
                                Comfortably numb...
                                • pbacotP Offline
                                  Damn, Pete, you even make toothbrushes have pizzazz.0 🎉
                                  • AdamBA Offline
                                    AdamB
                                    +1 Pete.
                                    Are those chipped tiles a texture, modelled, or is it a displacement?
                                    Adam
                                    • david_hD Offline
                                      david_h
                                      you have made much progress Grasshopper.
                                      When you can grab the thea-rendered toothbrush from my hand. . .then will you finally be ready. .
                                        Roger
                                        Radial glare is partly an artifact of the good old days of film where it was called halation. We may forget that film has thickness. Light enters the film to make an image but the strong light from highlights hits the rear of the film and bounces to the front and is then redirected to the rear. On longer exposures this excess light bouncing migrates away from the original point of contact just like a drop of water on a paper towel spreads out. Modern films have an antihalation backing to absorb excess light but it is not 100 percent effective, hence the halation (as in halo).
                                        http://www.azcreative.com
                                        • soloS Offline
                                          solo
                                          @adamb said:
                                          +1 Pete.
                                          Adam
                                          Niether, it's a texture from online, I added a bump which I generated with Pixplant2,I gave the bump a value of 30% (pretty high for Thea) thus the displacement feel.
                                            Pete, those images are really nice. the glare certainly adds something.
                                            Roger, I miss those thick films. And my old Graphic View 4x5 with the red leather bellows. 😉
                                            • 2 / 3
