    Dojo
    42 Posts 20 Posters 4.1k Views 20 Watching
    • AdamBA
      AdamB
      Beautiful. You really are getting the hang of this modelling thing, aren't you. β˜€
      Pete, what does Glare actually do? Its a blending function, or a lighting function?
        sepo
        Glare is related to lighting .... but in Thea it is postprocess.
        • soloS
          Adam,
          I guess the best way to describe it would be as a post render lighting effect in Thea, you have two options, first there is the Radial which is very like a bloom effect and the other is the Blade method which is like light flare effect, both are very customisable with parameters to set amount and size.
            πŸ‘ πŸ‘
            • soloS
              Here is an example of the glare radial effect.
              SU model:
              http://img442.imageshack.us/img442/8811/toothbrushinglasliness.jpg
              Straight Thea render, no glare:
              http://img256.imageshack.us/img256/8863/toothbrushinglas.jpg
              With 4% radius glare 20% Weight:
              http://img199.imageshack.us/img199/7639/toothbrushglasglares.jpg
              • numbthumbN
                numbthumb
                Somehow I missed this. But it doesnΒ΄t change the fact that I enjoy every look of it. Plus IΒ΄ve learned something new today πŸ‘
                Comfortably numb...
                • pbacotP
                  Damn, Pete, you even make toothbrushes have pizzazz.0 πŸŽ‰
                  • AdamBA
                    AdamB
                    +1 Pete.
                    Are those chipped tiles a texture, modelled, or is it a displacement?
                    Adam
                    • david_hD
                      david_h
                      you have made much progress Grasshopper.
                      When you can grab the thea-rendered toothbrush from my hand. . .then will you finally be ready. .
                        Roger
                        Radial glare is partly an artifact of the good old days of film where it was called halation. We may forget that film has thickness. Light enters the film to make an image but the strong light from highlights hits the rear of the film and bounces to the front and is then redirected to the rear. On longer exposures this excess light bouncing migrates away from the original point of contact just like a drop of water on a paper towel spreads out. Modern films have an antihalation backing to absorb excess light but it is not 100 percent effective, hence the halation (as in halo).
                        http://www.azcreative.com
                        • soloS
                          @adamb said:
                          +1 Pete.
                          Adam
                          Niether, it's a texture from online, I added a bump which I generated with Pixplant2,I gave the bump a value of 30% (pretty high for Thea) thus the displacement feel.
                            Pete, those images are really nice. the glare certainly adds something.
                            Roger, I miss those thick films. And my old Graphic View 4x5 with the red leather bellows. πŸ˜‰
                              Roger
                              Roger, I missthose thick films. And my old Graphic View 4x5 with the red leather bellows. πŸ˜‰
                              Before I became as vintage as the camera.
                              I still have one handy. You can tell I was enjoying the process. But over the Atlantic highlands at 2000 ft with the door open in late fall, it was cold even with double gloves.
                                I was thinking of one like this.
                                http://graflex.org/articles/graphic-view/I.jpg
                                But I had a couple of Speed graphics, too. The focal plane shutter would almost rip the camera from your hands if you weren't careful. πŸ˜„
                                I had a lovely ancient Kodak 137mm lens on the Graphic View. I'd had the lens recoated and liked the quality of images I got from it. Sold the camera and the lens for $100. I wish I'd just kept it.
                                • 2 / 3
