    [Plugin] Solids Trim and Keep (Pro Only)
    34 Posts 12 Posters 34.2k Views 12 Watching
    • J
      Jim
      If you have ever used SketchUp's Solid Tools you may have noticed their annoying behavior which converts your Components into Groups.
      This plugin allows you to trim a Component and have all instances update as well. It uses SketchUp's built-in Trim tool (thus Pro only,) but then does some post-operation clean-up. It renames the original Component and leaves it in the Component Browser, so you may want to Purge Unused Components after using it.
      Requirements
      • SketchUp Pro version >= 8
      Use:
      1. Select Trim and Keep from the Tools menu.
      2. Select the "cutter" solid.
      3. Select the solid to "keep"
      4. Optionally repeat from step 2
      5. Optionally Purge Unused Components
      Download
      jf_trim_and_keep.rb
      Install
      Move or copy the downloaded file to your Plugins folder. Restart SketchUp.
        Excellent! This is a huge improvement over the Solid Tools Trim tool. This works the way I think they should have made it work from the beginning.
        Thank you Jim.
        • TIGT
          Thanks Jim, to remove the now unused original definition from the model you need to add this line just before the model.commit_operation line...
          def_to_keep.entities.erase_entities(def_to_keep.entities.to_a)
          πŸ˜„
          [OR give the user a choice to keep/remove the now unused definition...]
          • EarthMoverE
            EarthMover
            Thanks Jim. Much needed improvement. It's always bugged me about Trim. πŸ‘
            Content Creator at Skapeup
            • irwanwrI
              irwanwr
              is there any way to make this plugin also available for free version too?
                As I understand it, the plugin utilizes the Solid Tools stuff that is only active in the pro version.
                • irwanwrI
                  irwanwr
                  yes, i see the info on the first post about the pro feature. thank you, Dave.
                  so there's no other similar plugin or something with independent program or code somewhere?
                    Well, you might check out Bool Tools. Not exactly the same but maybe it'll do what you need.
                    • irwanwrI
                      irwanwr
                      thank you Dave. i think that's a pro plugin though. if only i have the cash and a job list to use the plugin perhaps. πŸ˜„
                        I believe Bool Tools will work on the free version of SketchUp but I understand if you need to have some paying clients to afford to buy it.
                        • utilerU
                          utiler
                          Well done, Jim! I would hope this is sorted in future versions of SU...
                          πŸ‘
                          Just Curious...
                          • bmikeB
                            bmike
                            Nice... will give it a go!
                            mike beganyi design + consulting llc
                            • irwanwrI
                              irwanwr
                              is this OSCoolean plugin have any similarity with this Solids Trim and Keep plugin?
                                I think it is similar to the Solid Tools. You should give it a try.
                                • bmikeB
                                  bmike
                                  Very nice!
                                  Been looking for this for a long long time!
                                  This is the way Solid components should act with the native solid tools.
                                  SketchUp Team:
                                  If I wanted to trim a group, I would have done so!
                                  Thanks much for this.
                                  • irwanwrI
                                    irwanwr
                                    it seems that OSCoolean is a good tool. though it doesn't really work well when i tried to use it. perhaps it needs some updates or something. i don't know for sure.
                                    • K
                                      ktkoh
                                      The BooTools works very well I think it was 10 bucks but well worth the money. It edits the selected component however it deletes the component used to do the editing so if you want both after the operation make a copy of the cutting component. I use it with the free version and have been very plesed
                                      Keith
                                      • irwanwrI
                                        irwanwr
                                        Keith
                                        which free version and where, Keith?
                                          @irwanwr said:
                                          Keith
                                          I think he was referring to the free version of sketchUp.
                                          • irwanwrI
                                            irwanwr
                                            i see. thank you Dave.
                                            well, 10 bucks in a 3rd world country wont be easy to get. πŸ˜›
                                            meanwhile, i guess i'll just stick to Curviloft. it needs some wireframing to do and it does do it's job very well for skinning πŸ˜„
                                            • 1 / 2
