    [Plugin] Solids Trim and Keep (Pro Only)
    34 Posts 12 Posters 33.8k Views 12 Watching
    • EarthMoverE
      EarthMover
      Thanks Jim. Much needed improvement. It's always bugged me about Trim. ๐Ÿ‘
      Content Creator at Skapeup
      • irwanwrI
        irwanwr
        is there any way to make this plugin also available for free version too?
          As I understand it, the plugin utilizes the Solid Tools stuff that is only active in the pro version.
          • irwanwrI
            irwanwr
            yes, i see the info on the first post about the pro feature. thank you, Dave.
            so there's no other similar plugin or something with independent program or code somewhere?
              Well, you might check out Bool Tools. Not exactly the same but maybe it'll do what you need.
              • irwanwrI
                irwanwr
                thank you Dave. i think that's a pro plugin though. if only i have the cash and a job list to use the plugin perhaps. ๐Ÿ˜„
                  I believe Bool Tools will work on the free version of SketchUp but I understand if you need to have some paying clients to afford to buy it.
                  • utilerU
                    utiler
                    Well done, Jim! I would hope this is sorted in future versions of SU...
                    ๐Ÿ‘
                    Just Curious...
                    • bmikeB
                      bmike
                      Nice... will give it a go!
                      • irwanwrI
                        irwanwr
                        is this OSCoolean plugin have any similarity with this Solids Trim and Keep plugin?
                          I think it is similar to the Solid Tools. You should give it a try.
                          • bmikeB
                            bmike
                            Very nice!
                            Been looking for this for a long long time!
                            This is the way Solid components should act with the native solid tools.
                            SketchUp Team:
                            If I wanted to trim a group, I would have done so!
                            Thanks much for this.
                            • irwanwrI
                              irwanwr
                              it seems that OSCoolean is a good tool. though it doesn't really work well when i tried to use it. perhaps it needs some updates or something. i don't know for sure.
                              • K
                                ktkoh
                                The BooTools works very well I think it was 10 bucks but well worth the money. It edits the selected component however it deletes the component used to do the editing so if you want both after the operation make a copy of the cutting component. I use it with the free version and have been very plesed
                                Keith
                                • irwanwrI
                                  irwanwr
                                  Keith
                                  which free version and where, Keith?
                                    @irwanwr said:
                                    Keith
                                    I think he was referring to the free version of sketchUp.
                                    • irwanwrI
                                      irwanwr
                                      i see. thank you Dave.
                                      well, 10 bucks in a 3rd world country wont be easy to get. ๐Ÿ˜›
                                      meanwhile, i guess i'll just stick to Curviloft. it needs some wireframing to do and it does do it's job very well for skinning ๐Ÿ˜„
                                      • GaieusG
                                        How could I overlook this plugin??? ๐Ÿ˜ฎ
                                        Thanks Jim!!! ๐Ÿ‘
                                          RODRIGOLEE
                                          its works to SketchUp 2014????
                                            @rodrigolee said:
                                            Install it in v2014 Pro and try it... report back...
