    [Plugin] Solids Trim and Keep (Pro Only)
    34 Posts 12 Posters 33.8k Views 12 Watching
      Excellent! This is a huge improvement over the Solid Tools Trim tool. This works the way I think they should have made it work from the beginning.
      Thank you Jim.
        Thanks Jim, to remove the now unused original definition from the model you need to add this line just before the model.commit_operation line...
        def_to_keep.entities.erase_entities(def_to_keep.entities.to_a)
        ๐Ÿ˜„
        [OR give the user a choice to keep/remove the now unused definition...]
        • EarthMoverE
          EarthMover
          Thanks Jim. Much needed improvement. It's always bugged me about Trim. ๐Ÿ‘
          Content Creator at Skapeup
          • irwanwrI
            irwanwr
            is there any way to make this plugin also available for free version too?
              As I understand it, the plugin utilizes the Solid Tools stuff that is only active in the pro version.
              • irwanwrI
                irwanwr
                yes, i see the info on the first post about the pro feature. thank you, Dave.
                so there's no other similar plugin or something with independent program or code somewhere?
                  Well, you might check out Bool Tools. Not exactly the same but maybe it'll do what you need.
                  • irwanwrI
                    irwanwr
                    thank you Dave. i think that's a pro plugin though. if only i have the cash and a job list to use the plugin perhaps. ๐Ÿ˜„
                      I believe Bool Tools will work on the free version of SketchUp but I understand if you need to have some paying clients to afford to buy it.
                      • utilerU
                        utiler
                        Well done, Jim! I would hope this is sorted in future versions of SU...
                        ๐Ÿ‘
                        Just Curious...
                        • bmikeB
                          bmike
                          Nice... will give it a go!
                          • irwanwrI
                            irwanwr
                            is this OSCoolean plugin have any similarity with this Solids Trim and Keep plugin?
                              I think it is similar to the Solid Tools. You should give it a try.
                              • bmikeB
                                bmike
                                Very nice!
                                Been looking for this for a long long time!
                                This is the way Solid components should act with the native solid tools.
                                SketchUp Team:
                                If I wanted to trim a group, I would have done so!
                                Thanks much for this.
                                • irwanwrI
                                  irwanwr
                                  it seems that OSCoolean is a good tool. though it doesn't really work well when i tried to use it. perhaps it needs some updates or something. i don't know for sure.
                                  • K
                                    ktkoh
                                    The BooTools works very well I think it was 10 bucks but well worth the money. It edits the selected component however it deletes the component used to do the editing so if you want both after the operation make a copy of the cutting component. I use it with the free version and have been very plesed
                                    Keith
                                    • irwanwrI
                                      irwanwr
                                      Keith
                                      which free version and where, Keith?
                                        @irwanwr said:
                                        Keith
                                        I think he was referring to the free version of sketchUp.
                                        • irwanwrI
                                          irwanwr
                                          i see. thank you Dave.
                                          well, 10 bucks in a 3rd world country wont be easy to get. ๐Ÿ˜›
                                          meanwhile, i guess i'll just stick to Curviloft. it needs some wireframing to do and it does do it's job very well for skinning ๐Ÿ˜„
                                          • GaieusG
                                            How could I overlook this plugin??? ๐Ÿ˜ฎ
                                            Thanks Jim!!! ๐Ÿ‘
