    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [req] follow me helix
    35 Posts 14 Posters 15.7k Views 14 Watching
    • soloS Offline
      solo
      I'm not sure if this already exists, I have looked but not found anything (then again I have not looked that hard)
      I'd like to add a spiral around a cable that is pretty free formed, normally I'd create the helix and use shape bender to create the shape but it only works on the red axis and the path I need it to follow is on all three axis.
      Anyone know if there is something like this out there?
      The above was the original request, and it was solved thanks to sdmitch.
      Ruby can be found here: http://forums.sketchucation.com/viewtopic.php?p=353348#p353348
      http://www.solos-art.com
      • mitcorbM Offline
        mitcorb
        I tried to construct a section of vine twining around itself using Tube Along Path, after constructing as you did, a welded series of spiraling segments. It is on a different computer than the one I am using. A method I used was setting up standoff segments "perpendicular" to the inner objects representing the radius of the vine, and connecting segments. Perhaps Follow Me and Keep? As far as helix around a helix, it hurt my head too much.
          Use shapebender three times with your helix rotating between transformations. So in effect your bending occurs all on red axis but transforms globally.
          Or Radial bending with FredoScale. Both these methods aren't absolute though since you assume certain bends.
          Or download MOI or Rhino trial and do this there.
          Another option is Tgi3D Warper tool locked in Parralell
            Try ExtrudeEdgesByFace ?
            You need to Weld the pseudo-helical path into a single curve [if it's not already one].
            Then draw the circular face [or any shape for that matter***], flat on the ground [face orientation up/down is not important, ***if the shape is non-symmetrical it's green/Y-axis becomes the blue/Z-axis as it first starts to extrude].
            Because you want the extrusion to be 'centered' you should also add a cpoint [guide] at the face's center.
            Now select the face, the cpoint and the path-curve... and run the tool...
            Spiral wire/pipe... done... โ˜€
            • soloS Offline
              solo
              I need something like this, the spiral needs to follow this crazy shape, then afterwards I need to use follow me to take the helix path from line to mesh. ๐Ÿ˜ฒ
                Can you post a simple SKP with the 'path' and suggested cross section circle...
                • soloS Offline
                  solo
                  sure.
                  helix to path.skp
                    You posted your image after I posted... ๐Ÿ˜•
                    You want to 'mutate' the helix along the path, then use FollowMe ???
                    Here's the pre-distorted path EEbyFace...Capture.PNG any ๐Ÿ˜’
                      I think I understand what you now want...
                      The helix itself to be twisted along the distorted-path...
                      Then you do the FollowMe ๐Ÿ˜’
                      Watch this space...
                      Think it CAN be done with ShapeBender... ๐Ÿ’ญ
                      • soloS Offline
                        solo
                        'randomly mutate'
                        Not sure what this means in SU terms, sounds like a Sci Fi term.
                        I guess the best way to describe what I need is telephone cord.
                        • boofredlayB Offline
                          boofredlay
                          @tig said:
                          Watch this space...
                          ๐ŸŽ‰ He's working!!!!!! ๐ŸŽ‰
                          This will be a cool plugin for sure if it happens.
                            IF ๐Ÿ˜’
                            that's IF! - not IF?
                              Here's a way of using ShapeBender with appropriately oriented/sized 'bits'; followed by Weld and then EEbyFace...Capture.PNG
                                Allo ? ๐Ÿ˜‰
                                • sdmitchS Offline
                                  sdmitch
                                  Something like this?
                                  http://sdmitch.blogspot.com/
                                    You nailed it. Is it a plugin?
                                    • soloS Offline
                                      solo
                                      Exactly like that!
                                      • sdmitchS Offline
                                        sdmitch
                                        Yes it is a plugin. It is a little rough around sharp corners and may take a little trial and error to get the input parameters just right. Pre-select the centerline then run plugin. You are prompted for the radius of the helix, and the linear and angular increments.
                                        Create a helix along pre-selected path
                                        • soloS Offline
                                          solo
                                          Excellent.
                                          Helix around bent helix:
                                          Most appreciated mate.
                                          • mitcorbM Offline
                                            mitcorb
                                            Congratulations, sdmitch, and thank you.
                                            • 2 / 2
