    [req] follow me helix
    35 Posts 14 Posters 16.9k Views 14 Watching
    • boofredlayB Offline
      boofredlay
      @tig said:
      Watch this space...
      πŸŽ‰ He's working!!!!!! πŸŽ‰
      This will be a cool plugin for sure if it happens.
        IF πŸ˜’
        that's IF! - not IF?
          Here's a way of using ShapeBender with appropriately oriented/sized 'bits'; followed by Weld and then EEbyFace...Capture.PNG
            Allo ? πŸ˜‰
            • sdmitchS Offline
              sdmitch
              Something like this?
              http://sdmitch.blogspot.com/
                You nailed it. Is it a plugin?
                • soloS Offline
                  Exactly like that!
                  • sdmitchS Offline
                    sdmitch
                    Yes it is a plugin. It is a little rough around sharp corners and may take a little trial and error to get the input parameters just right. Pre-select the centerline then run plugin. You are prompted for the radius of the helix, and the linear and angular increments.
                    Create a helix along pre-selected path
                    • soloS Offline
                      Excellent.
                      Helix around bent helix:
                      Most appreciated mate.
                      • mitcorbM Offline
                        mitcorb
                        Congratulations, sdmitch, and thank you.
                          boofredlay
                          Woah, great work Sam!
                          • soloS Offline
                            Eric,
                            That must have taken some time to 'follow me' 😲
                            • EarthMoverE Offline
                              EarthMover
                              Reminds me of the days before cordless phones! πŸ˜†
                              Content Creator at Skapeup
                                boofredlay
                                Ha ha, no Pete, I just changed the profiles of the lines to 5 and did a screengrab.
                                • tridemT Offline
                                  tridem
                                  it works magic! Thanks sdmitch
                                  • numbthumbN Offline
                                    numbthumb
                                    Thank you, sdmitch!
                                    Comfortably numb...
                                      boofredlay
                                      You know what Pete, it was late last night and I think I read your question wrong. It did take some time for the helix to follow that path. I thought you meant I did a pipe along path afterwards. Sorry.
                                      This plugin is nice for making stitching. Just run it then scale the helix to almost flat. Around a curve might take some tweaking like I did for this one. I actually made the helix on one segment, scaled it "flat" then copied it around the curve. I am also finding out that the longer the helix the less responsive it is to moving or editing. Even though the straight line one is just that, a straight line, it was difficult to manipulate. Best bet is to do a short segment then copy it inside a group or component.
                                      Anyway, enough of my rambling.
                                        EarthMover
                                        Perhaps change the OP to reflect [Plugin] and attach the script to the first post.
                                          Jim
                                          But best to start a new post.
                                          • I Offline
                                            ivreich
                                            cool plugin!
                                            next step: allow the helix radius to change along center path according to target points. πŸ’š
                                            joel
