    [req] follow me helix
    35 Posts 14 Posters 17.5k Views 14 Watching
      Try ExtrudeEdgesByFace ?
      You need to Weld the pseudo-helical path into a single curve [if it's not already one].
      Then draw the circular face [or any shape for that matter***], flat on the ground [face orientation up/down is not important, ***if the shape is non-symmetrical it's green/Y-axis becomes the blue/Z-axis as it first starts to extrude].
      Because you want the extrusion to be 'centered' you should also add a cpoint [guide] at the face's center.
      Now select the face, the cpoint and the path-curve... and run the tool...
      Spiral wire/pipe... done... β˜€
      • soloS Offline
        I need something like this, the spiral needs to follow this crazy shape, then afterwards I need to use follow me to take the helix path from line to mesh. 😲
          Can you post a simple SKP with the 'path' and suggested cross section circle...
          • soloS Offline
            sure.
            helix to path.skp
              You posted your image after I posted... πŸ˜•
              You want to 'mutate' the helix along the path, then use FollowMe ???
              Here's the pre-distorted path EEbyFace...Capture.PNG any πŸ˜’
                I think I understand what you now want...
                The helix itself to be twisted along the distorted-path...
                Then you do the FollowMe πŸ˜’
                Watch this space...
                Think it CAN be done with ShapeBender... πŸ’­
                • soloS Offline
                  'randomly mutate'
                  Not sure what this means in SU terms, sounds like a Sci Fi term.
                  I guess the best way to describe what I need is telephone cord.
                  • boofredlayB Offline
                    boofredlay
                    @tig said:
                    Watch this space...
                    πŸŽ‰ He's working!!!!!! πŸŽ‰
                    This will be a cool plugin for sure if it happens.
                      IF πŸ˜’
                      that's IF! - not IF?
                        Here's a way of using ShapeBender with appropriately oriented/sized 'bits'; followed by Weld and then EEbyFace...Capture.PNG
                          Allo ? πŸ˜‰
                          • sdmitchS Offline
                            sdmitch
                            Something like this?
                            http://sdmitch.blogspot.com/
                              You nailed it. Is it a plugin?
                              • soloS Offline
                                Exactly like that!
                                • sdmitchS Offline
                                  sdmitch
                                  Yes it is a plugin. It is a little rough around sharp corners and may take a little trial and error to get the input parameters just right. Pre-select the centerline then run plugin. You are prompted for the radius of the helix, and the linear and angular increments.
                                  Create a helix along pre-selected path
                                  • soloS Offline
                                    Excellent.
                                    Helix around bent helix:
                                    Most appreciated mate.
                                    • mitcorbM Offline
                                      mitcorb
                                      Congratulations, sdmitch, and thank you.
                                        boofredlay
                                        Woah, great work Sam!
                                        • soloS Offline
                                          Eric,
                                          That must have taken some time to 'follow me' 😲
                                          • EarthMoverE Offline
                                            EarthMover
                                            Reminds me of the days before cordless phones! πŸ˜†
                                            Content Creator at Skapeup
