    Reverse displacement :(
    renderpluginsextensions
    5 Posts 3 Posters 928 Views 3 Watching
    • john2J Offline
      john2
      i'm trying to render a brick wall in vray. But on applying the displacement map, vray misrecognizes it and pulls the mortar apart. My displacement map has brick as white and the mortar as black. I also tried making the displacement map vice versa that is white mortar and black bricks. But vray is doing opposite in both cases. πŸ˜•
        You're saying you get the same result regardless if you invert your displacement map?
        • john2J Offline
          john2
          yes 😞
            Can you post a sample file?
            I have not seen this behaviour.
            Also; exactly what version number of VfSU do you use?
              rc6
              brick problem.rar
