    Reverse displacement :(
    renderpluginsextensions
    5 Posts 3 Posters 1.0k Views 3 Watching
    • john2J Offline
      john2
      i'm trying to render a brick wall in vray. But on applying the displacement map, vray misrecognizes it and pulls the mortar apart. My displacement map has brick as white and the mortar as black. I also tried making the displacement map vice versa that is white mortar and black bricks. But vray is doing opposite in both cases. πŸ˜•
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        You're saying you get the same result regardless if you invert your displacement map?
        • john2J Offline
          john2
          yes 😞
            Can you post a sample file?
            I have not seen this behaviour.
            Also; exactly what version number of VfSU do you use?
              rc6
              brick problem.rar
