    Sketchup X-Ray / Back Edges bug
    16 Posts 3 Posters 2.2k Views 3 Watching
    • dereiD
      derei
      I noticed that "Back Edges" visual style is not supported inside components/groups. I think this can be considered a bug, because its corespondent: X-Ray, can be used in any circumstance. See attached images.
      DESIGNER AND ARTIST DEREI.UK
      • GaieusG
        That must be something on your end. To me they display properly - I can even select and move them around...
        • dereiD
          derei
          Here is the model. I can't understand what is happening and why.
          Please check if it's happening to you too.
          Cabinet.skp
          • GaieusG
            Hm. Indeed I do not have them in edit mode either. Let me play around a bit more...
            Edit: If hide rest of model is active, the back edges disappear in group/component edit mode. But if you unhide the rest of the model, they appear. Can you confirm?
            (Do you use this feature? Window > Model info > Components. I have a shortcut for this)
            Yes, and it is still a bug.
            • thomthomT
              I see the same thing. But I also find that turning off Hide Rest of Model displays the backedges. But that's still a behaviour I only see in that model...
              • thomthomT
                Must be the style. I just switched to one of the SketchUp default styles and it display back edges in components with Hide Rest of Model.
                • GaieusG
                  Indeed style setting - still a bug IMO. If you set transparency to medium or faster, the back edges appear correctly.
                  • thomthomT
                    Ah! When Transparency is set to Nicer, and Hide Rest of Model is enabled, and you are inside a group/component - back edges doesn't display!
                    This smells like a bug.
                    • thomthomT
                      Gaieus beat me to it... πŸ˜’
                      • thomthomT
                        How it can be reported: http://forums.sketchucation.com/viewtopic.php?f=11&t=29023
                        πŸ˜‰
                        • GaieusG
                          Also to Millard McQuaid in email.
                          • dereiD
                            derei
                            That is the correct behavior. I checked my style and transparency was set to "nicer". Also I can confirm that hiding the rest of model affects back edges.
                            Thank you.
                            • GaieusG
                              Well, I would not necessarily call it "correct" behaviour. Maybe "actual" behaviour. In fact if anything, nicer should display these settings the best - and of course, hiding the rest of the model should not have any kind of effect on this setting.
                              • thomthomT
                                I often find that Medium produce better result than Nicer for some odd reasons...
                                • GaieusG
                                  Probably nicer taxes the video system too much. I have medium set in my default template so often I do not notice things that others do.
                                  • dereiD
                                    derei
                                    I said "correct" meaning that is how you said in the earlier post... I was confirming your findings. Sorry for confusion. πŸ˜„
