    Sketchup X-Ray / Back Edges bug
    16 Posts 3 Posters 2.2k Views 3 Watching
      I see the same thing. But I also find that turning off Hide Rest of Model displays the backedges. But that's still a behaviour I only see in that model...
        Must be the style. I just switched to one of the SketchUp default styles and it display back edges in components with Hide Rest of Model.
        • GaieusG
          Indeed style setting - still a bug IMO. If you set transparency to medium or faster, the back edges appear correctly.
            Ah! When Transparency is set to Nicer, and Hide Rest of Model is enabled, and you are inside a group/component - back edges doesn't display!
            This smells like a bug.
              Gaieus beat me to it... πŸ˜’
                How it can be reported: http://forums.sketchucation.com/viewtopic.php?f=11&t=29023
                πŸ˜‰
                • GaieusG
                  Also to Millard McQuaid in email.
                  • dereiD
                    derei
                    That is the correct behavior. I checked my style and transparency was set to "nicer". Also I can confirm that hiding the rest of model affects back edges.
                    Thank you.
                    DESIGNER AND ARTIST DEREI.UK
                    • GaieusG
                      Well, I would not necessarily call it "correct" behaviour. Maybe "actual" behaviour. In fact if anything, nicer should display these settings the best - and of course, hiding the rest of the model should not have any kind of effect on this setting.
                        I often find that Medium produce better result than Nicer for some odd reasons...
                        • GaieusG
                          Probably nicer taxes the video system too much. I have medium set in my default template so often I do not notice things that others do.
                          • dereiD
                            derei
                            I said "correct" meaning that is how you said in the earlier post... I was confirming your findings. Sorry for confusion. πŸ˜„
