    [Plugin] ReGlue
    35 Posts 11 Posters 14.8k Views 11 Watching
      There is a method:
      glued = face.get_glued_instances
      And it'd be easy to grep then iterate all of the faces and their glued components etc...
      BUT there's no API ' .could_be_glued_instances' method...
      BUT here's some possible [pretty much untested] code which might just do it...
      ctr=0
      model=Sketchup.active_model
      faces=model.active_entities.grep(Sketchup;;Face)
      comps=model.active_entities.grep(Sketchup;;ComponentInstance).find_all{|e|
        e.definition.behavior.is2d? && ! e.glued_to
      ### collect if comp can glue, but not glued !
      cct=comps.length
      faces.each{|f|
        plane=f.plane
        norm =f.normal
        comps.dup.each{|e|
          pt=e.transformation.origin
          nm=e.transformation.zaxis
          if pt.distance_to_plane(plane)==0 && norm==nm
            ### glue-able
            cp=f.classify_point(pt)
            if cp==Sketchup;;Face;;PointInside || cp==Sketchup;;Face;;PointOnEdge || cp==Sketchup;;Face;;PointOnVertex
              ### on face so can glue
              e.glued_to=f
              comps.delete(e)
              ctr+=1
              ### reduce tested comps collection for speed
      puts "\n\nReglued #{ctr} of #{cct}" ### print how many reglued
        rv1974
        @TIG This plugin reglues multiple components in SU 2022. In v2023 and newer it reglues only one component.
        What is the reason for this degradation? Thanks
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @rv1974
          @rv1974
          This plugin is over a decade old !
          As far as I recall, and tell from the code and version, it has always needed a selection of one face and one component to work. for 19 years.
          Although I do see from my posts do speaks of one or more components being processed...
          As far as I can see this old code is very simplistic... e.g.
          It does not check for gluing properties, or face-normal, or Z-axis, or position on the face.plane, or transformation.origin point on the face at all.
          If it checked for several components being on the face and sharing the face.normal as their Z-axis etc, then it would be possible the get it to process several gluing components. However, this would require a complete rewrite...
          I'll back check...
            Here's v2.0 in the PluginStore...
            https://sketchucation.com/pluginstore?pln=Re_Glue
            It now allows multiple pre selected component-instances, but still only one preselected face.
            These are glued to the face [is possible], any errors or unsuitable instances are reported in the Ruby Console...
            R 1 Reply Last reply Reply Quote 1
              rv1974 @TIG
              @TIG Many thanks!
              designerbursaD 1 Reply Last reply Reply Quote 0
              • designerbursaD Offline
                designerbursa @rv1974
                @rv1974
                def self.glue_components_to_faces
                  model = Sketchup.active_model
                  selection = model.selection
                  return UI.messagebox("Error: No selection!") if selection.empty?
                  faces = selection.grep(Sketchup::Face)
                  components = selection.grep(Sketchup::ComponentInstance)
                  return UI.messagebox("Error: Select faces and components!") if faces.empty? || components.empty?
                  model.start_operation("Glue Components to Faces", true)
                  begin
                    components.each do |component|
                      closest_face = find_closest_aligned_face(component, faces)
                      component.glued_to = closest_face if closest_face
                  ensure
                    model.commit_operation
                def self.find_closest_aligned_face(component, faces)
                  component_normal = component.transformation.zaxis
                  closest_face = faces.min_by { |face| face.normal.angle_between(component_normal) }
                  closest_face
                R 1 Reply Last reply Reply Quote 0
                  rv1974 @designerbursa
                  @designerbursa what do you mean?
                    @rv1974 I developed the code for pasting on all selected surfaces at once, it would be useful for everyone if it is updated in this way.
                      @designerbursa
                      I might be missing something but currently I can do it without any plugin
                        @rv1974 If you can paste without extensions, I really congratulate you...
                          @designerbursa
                            @rv1974 I am using Sketchup 2021 version
                              designerbursa @designerbursa
                              @designerbursa ```
                              module GlueComponentsToFaces
                                extend self
                                def glue_components_to_faces
                                  if selection.empty?
                                    return UI.messagebox("Error: No selection! Please select faces and components.")
                                  begin
                                  rescue => e
                                    UI.messagebox("An error occurred: #{e.message}")
                                  ensure
                                def find_closest_aligned_face(component, faces)
                                  closest_face
                              # Adding a menu item for ease of use in SketchUp
                              if not file_loaded?(__FILE__)
                                UI.menu("Plugins").add_item("Glue Components to Faces") {
                                  GlueComponentsToFaces.glue_components_to_faces
                                file_loaded(__FILE__)
                              ### I haven't tested it on the 2024 version but you can try this, maybe it will work. It works smoothly on my 2021 version
                                @designerbursa I took a closer look.. your version is indeed more advanced and user friendly, many thanks!
                                P.S. you can cut and paste in place multiple and un-glued components in any SU version to get the same positive result, but your script is less laborious indeed.
                                  designerbursa
                                  module Reglue
                                      extend self
                                      # Menü öğesinin eklenme konumunu belirleyen değişken
                                      SUPPORT_MENU_POSITION ||= Sketchup::Menu.instance_method(:add_item).arity != 1 ? 8 : nil
                                        if selection.empty?
                                          UI.messagebox("Hata: Hiçbir seçim yapılmadı!")
                                          return
                                        components = selection.grep(Sketchup::ComponentInstance).select { |comp| comp.glued_to.nil? }
                                          UI.messagebox("Hata: Lütfen hem yüzeyleri hem de yapıştırılabilir bileşenleri seçin!")
                                          return
                                        model.start_operation("Bileşenleri Yüzeylere Yeniden Yapıştır", true)
                                      unless @loaded
                                        UI.add_context_menu_handler do |menu|
                                          selection = Sketchup.active_model.selection
                                          next if selection.empty?
                                          has_faces = selection.any? { |entity| entity.is_a?(Sketchup::Face) }
                                          has_glueable_components = selection.any? { |entity| entity.is_a?(Sketchup::ComponentInstance) && entity.glued_to.nil? }
                                          if has_faces && has_glueable_components
                                            position = SUPPORT_MENU_POSITION
                                            menu.add_item("Reglue", position) { glue_components_to_faces }
                                        @loaded = true
                                  • 2 / 2
