    2d CAD topo into a 3d
    12 Posts 4 Posters 868 Views 4 Watching
    • leedeeteeL Offline
      leedeetee
      Hi guys,
      I've got a 2d cad topo plan that I'd like to have in 3d so that I can model an embankment where we are putting an elevated walkway onto/into. Unfortunately, the architects have informed me the topo is 2d only. 🀒
      So, the only way roudn this I can think of is to extrude lines from the spot heights and then triangulate the levels.
      Am I missing a trick here? Is there an easier way?
      Cheers.
        Instead of extruding you can just move the lines. Saves you from creating extra geometry, but it's still tedious labor.
        (yes - 2d topo plans sucks - cursed be them!)
          leedeetee
          Thank-you Thom. I thought of moving the spot heights (crosshairs) but though it might make triangualtion even more tedious.
            Is your topo from edges or construction points?
            If you have just point, when use a triangulation plugin: http://forums.sketchucation.com/viewtopic.php?t=34232
              If you have the 2d info as a DWG with text for the spot heights - even if 'flat' I do have some AutoLisp stuff I made ages ago to add cpoints at the right heights reading the text as numerals - you can then import those as the cpoints cloud etc to make the surface...
              If you PM me a zipped DWG of the site info I'll see what I can do... πŸ˜•
                leedeetee
                TIG, that would be super kind of you and is an amazing gesture. I'll send you a PM now. Thanks so much.
                • V Offline
                  valerostudio
                  The way I handle this is to cleanup the CAD file with just topo lines. In AutoCAD, have the properties window open and click the line (hopefull a Pline or Spline) and change the Z elevation property of the line. This may take a while on a big site, but without a LISP, its the best way. Then import this file into SU and select all the lines and run the Simplify contours plugin and then run the terrain from contours sandbox tool. Final step - bill the architect for all of those hours spent on the model!
                    Done and dusted πŸ˜• I hope...
                      leedeetee
                      Thanks so much TIG, absolutely brilliant of you.
                      I owe you a pint of Gold Tankard from Wylam (one of my faves and near you by your profile).
                      πŸ˜„
                        He's got a PayPal donation page. πŸ˜‰
                          Paypal doesn't accept beer!
                          However, I do πŸ˜‰
                          If you ever plan to be in the NE let me know... πŸ˜„
                            leedeetee
                            However, I do πŸ˜‰
                            Could you point me to it, please?
                            Love Northumberland, went to Newcastle uni and lived up there for 6 years, on and off, in total. Even proposed on Holy Island. Lot's of happy memories. πŸ˜„
