    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.5k Views 116 Watching
      @thomthom said:
      When you go to Window > Preferences > Extensions you can find the version from there.
      I'll add an About menu to the next version.
      If you want to add it only for version, you can add version in toolbar name.
      Nah - I don't want to add version to menus and toolbars. Because then shortcut keys would break at every update. SketchUp reference them by their names.
        Important!
        All users should update TT_Lib2 to version 2.6.0
          Thank You
            • gillesG Offline
              gilles
              it's ok now with TT_LIB 2.6 it is not yet in plugin index so i had 2.58
              thanks
                I released TT_Lib2 2.6 just a few hours ago... 😉
                • fredo6F Offline
                  fredo6
                  @thomthom said:
                  Tom,
                  Here is the model where I have problem (I get the UV axes, but the texture does not appear).
                  [attachment=0:3fo0zvrn]<!-- ia0 -->Quad-mapping Fred.png<!-- ia0 -->[/attachment:3fo0zvrn]
                  Fredo
                  Might be related to the nil errors people are reporting...
                  This is the message I get
                  Error; #<TypeError; nil can't be coerced into Float>
                  D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `/'
                  D;/Documents/Doc/AA_SKU/Ruby/AAA_SCRIPT6/TT_QuadFaceTools/uv_mapping.rb;820;in `point_on_axis'
                  EDIT: this is with v0.4. I did not upgrade yet
                  Fredo
                  • fredo6F Offline
                    fredo6
                    @charly2008 said:
                    Hi Fredo,
                    I think you need before placing the texture on the face. Then you can scale the texture. Whether it is possible to be centered I do not know.
                    Thanks. Once I have the texture on the shape, what should I do next?
                    Fredo
                      How about 0.4.1?
                      (I'm prepping up 0.5 which included quite a few validations and error catching. Should be more informative when things doesn't work.)
                      Then you can click the axis (red and green line) to scale it. Or use the VCB.
                        jorge2011
                        thom excellent, now works fine.
                        thank you very much for your fast response
                        • charly2008C Offline
                          charly2008
                          I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
                          wiking.skp
                            huh! ... peculiar... I'll look into it.
                            Nice boat! 😄
                              How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
                                I found the cause - you got some messed up geometry there.
                                Look at this screenshot:
                                Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
                                Now look at this one - where I made the same selection around the troublesome area:
                                Notice there is 20 (!) entities. Something is messed up in your geometry there.
                                  Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
                                    Version 0.5.0
                                    Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
                                    Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
                                      charly2008
                                      Hi Thomas,
                                      I did it with the UV Copy & Paste tools.
                                        charly2008
                                        I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
                                          charly2008
                                          Hi Thomas,
                                          I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
                                          Charly
                                          STEP 1
                                          STEP 2
                                          STEP 3
                                          wiking.skp
                                            It's still some non-quads over at that end.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 33
                                            • 34
                                            • 8 / 34
