    [Plugin] QuadFaceTools
    680 Posts 116 Posters 713.8k Views 116 Watching
      jorge2011
      thom excellent, now works fine.
      thank you very much for your fast response
      • charly2008C Offline
        charly2008
        I made another attempt with my Viking ship hull. This tool is really amazing. A small error I could not resolve.
        wiking.skp
          huh! ... peculiar... I'll look into it.
          Nice boat! 😄
            How did you map it? With the UV Mapping tool, or with the UV Copy & Paste tools?
              I found the cause - you got some messed up geometry there.
              Look at this screenshot:
              Here I made a left to right selection over the selected quad. Notice the Entity Info correctly displaying 7 entities. ( 2 triangles, 5 edges )
              Now look at this one - where I made the same selection around the troublesome area:
              Notice there is 20 (!) entities. Something is messed up in your geometry there.
                Zoom in to the top left corner of that white and see a whole lot of extra edges and faces
                  Version 0.5.0
                  Changelog: https://bitbucket.org/thomthom/quadface-tools/issues?status=resolved&version=0.5.0
                  Download: https://bitbucket.org/thomthom/quadface-tools/wiki/Download
                    charly2008
                    Hi Thomas,
                    I did it with the UV Copy & Paste tools.
                      charly2008
                      I found the error. As Gaieus said, in the enlargement can be seen some additional faces. This I have now adjusted.
                        charly2008
                        Hi Thomas,
                        I'm still have a few problems with copy and paste UVs. It is probably a mistake from me again. Would you again take a look at it.
                        Charly
                        STEP 1
                        STEP 2
                        STEP 3
                        wiking.skp
                          It's still some non-quads over at that end.
                            charly2008
                            Hi Thomas,
                            I thank you for your efforts. I'm sometimes a bit hasty with my questions. In the future I will take a closer look before I ask a question.
                            Charly
                              charly2008
                              Hi Thomas,
                              Once it has worked with the hull I need help again. I do not succeed, to bring the texture on these relatively simple geometry. As far as I can judge it must be all quad faces in the model. Yesterday I spent two hours trying to find the error in the geometry, without success. Thanks in advance.
                              Charly
                              wiking3.skp
                              • jo-keJ Offline
                                jo-ke
                                Thank you ThomThom for this wonderful plugin. It helps me a lot with my curtains...
                                http://www.zz7.de
                                  @charly2008 said:
                                  Hi Thomas,
                                  Charly
                                  Are you using the Copy and Paste function? Or the UV map function?
                                  • mitcorbM Offline
                                    mitcorb
                                    Wow!
                                    Eleven pages and counting. Good work ThomThom
                                      charly2008
                                      Hi Thomas,
                                      I've just tried it again and it worked. I do not know what mistake I made.
                                        charly2008
                                        Not yet perfect but a step in the right direction with the help of the Quad Face tool from Thomas.
                                          Really glad to see some if the stuff this plugin is being used for. 😄
                                            shumas
                                            Problem! when i copy all files to sketchup 8 plugin directory, and open sketchup, I get this error.. I'm doing something wrong?
                                            • 33
                                            • 34
                                            • 8 / 34
