    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.1k Views 116 Watching
      Sensational, TT. Now I can make my Arch texturing tutorial #3! 😍
        Looking forward to it!
          jorge2011
          thank you very much for this excellent update. is excellent.
          unfortunately I have a problem:). sketchup generates the following error:
          Error al cargar archivo C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
          undefined method to_l' for nil:NilClassError al cargar archivo tt_quadface.rb undefined method to_l' for nil:NilClass
          how I can fix this?
            how I can fix this?
            When do you get this error?
              jorge2011
              when I start sketchup
                What version of TT_Lib2 do you have?
                  jorge2011
                  the last version
                    jorge2011
                    is odd. install this plugin yesterday and worked well.
                    Today I went back to start and generated that error sketchup
                      @jorge2011 said:
                      the last version
                      Can you check exactly what version you have to be sure? Type TT::Lib::VERSION into the Ruby Console. I just want to make sure as I've had cases before where users thought they had the latest, but turned out that they didn't.
                      Does it give you that error every time?
                      If so, after you started SU, can you open the Ruby Console and type: load 'tt_quadface.rb' and post back any errors if there is any.
                        jorge2011
                        TT::Lib::VERSION 2.5.8
                        When I write load 'tt_quadface.rb' , ruby console generates the following message:
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:20: warning: already initialized constant PLUGIN
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:21: warning: already initialized constant PLUGIN_ID
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:22: warning: already initialized constant PLUGIN_NAME
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:24: warning: already initialized constant PLUGIN_VERSION
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:27: warning: already initialized constant PATH_ROOT
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:28: warning: already initialized constant PATH
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:29: warning: already initialized constant PATH_ICONS
                        Error: #<NoMethodError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:51:in []': undefined method to_l' for nil:NilClass>
                        (eval)
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:90:in set_default' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb:45 C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in require'
                        C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in load' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:41:in register_extension'
                        (eval):0:in `load'
                        (eval):0
                        I use
                        Sketchup 8 in Spanish y windows xp sp3
                          jorge2011
                          thom thank you very much for your time.
                          but.
                          re-install the program sketchup, and now the plugin works fine. I can not have that problem occurred but works fine
                          πŸ˜„ thank
                            It works? Good - glad it does.
                            That last error you posted guides me to where to look. I'll look at the code and see what I can do to avoid it.
                            • N Offline
                              notareal
                              @thomthom said:
                              Version 0.4.0
                              Important!
                              This version redefines what a QuadFace is. In order to use quad face meshes used by older versions you must update them.
                              Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
                              Stunning... You have done amazing work. I hope this will inspire others too. Thank you!
                              • PixeroP Offline
                                Pixero
                                Thanks soo much. Will study it.
                                  Has anyone gotten around to try the UV mapping feature?
                                  I know it has some issues and the UI needs improving.
                                  What worked and what didn't work? What's unclear and what is not?
                                    I did some quick tests.
                                    When using "Unwrap Picked Grid" it'd be nice if it used inferencing.
                                    Sometimes the texture reverses though I haven't reproduced this regularly.
                                    Other than that it's nomnomnomnomnomnomnomnomnomnomnom
                                      For placing the grid?
                                      O'RLY? o_O Let me know if you can reproduce it. And even if you can't, post the result?
                                      Btw, that UV test tile you got there... ?
                                        What about my UV test tile? You don't like it?
                                          yes for placing the grid
                                            • 6
                                            • 33
                                            • 34
                                            • 4 / 34
