    [Plugin] QuadFaceTools
    680 Posts 116 Posters 744.9k Views 116 Watching
      jorge2011
      TT::Lib::VERSION 2.5.8
      When I write load 'tt_quadface.rb' , ruby console generates the following message:
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:20: warning: already initialized constant PLUGIN
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:21: warning: already initialized constant PLUGIN_ID
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:22: warning: already initialized constant PLUGIN_NAME
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:24: warning: already initialized constant PLUGIN_VERSION
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:27: warning: already initialized constant PATH_ROOT
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:28: warning: already initialized constant PATH
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:29: warning: already initialized constant PATH_ICONS
      Error: #<NoMethodError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:51:in []': undefined method to_l' for nil:NilClass>
      (eval)
      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_Lib2/settings.rb:90:in set_default' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb:45 C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in require'
      C:/Archivos de programa/Google/Google SketchUp 8/Tools/extensions.rb:36:in load' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_quadface.rb:41:in register_extension'
      (eval):0:in `load'
      (eval):0
      I use
      Sketchup 8 in Spanish y windows xp sp3
        jorge2011
        thom thank you very much for your time.
        but.
        re-install the program sketchup, and now the plugin works fine. I can not have that problem occurred but works fine
        πŸ˜„ thank
          It works? Good - glad it does.
          That last error you posted guides me to where to look. I'll look at the code and see what I can do to avoid it.
          • N
            notareal
            @thomthom said:
            Version 0.4.0
            Important!
            This version redefines what a QuadFace is. In order to use quad face meshes used by older versions you must update them.
            Tools > QuadFace Tools > Convert > Sandbox Quads to QuadFace Quads
            Stunning... You have done amazing work. I hope this will inspire others too. Thank you!
            • PixeroP
              Pixero
              Thanks soo much. Will study it.
                Has anyone gotten around to try the UV mapping feature?
                I know it has some issues and the UI needs improving.
                What worked and what didn't work? What's unclear and what is not?
                  I did some quick tests.
                  When using "Unwrap Picked Grid" it'd be nice if it used inferencing.
                  Sometimes the texture reverses though I haven't reproduced this regularly.
                  Other than that it's nomnomnomnomnomnomnomnomnomnomnom
                    For placing the grid?
                    O'RLY? o_O Let me know if you can reproduce it. And even if you can't, post the result?
                    Btw, that UV test tile you got there... ?
                      What about my UV test tile? You don't like it?
                        yes for placing the grid
                            Yea I do. I gives a larger illustration of the UV flow.
                            @tig said:
                            Here are a couple I use.
                            πŸ‘ πŸ‘
                            • PixeroP
                              Pixero
                              Hmm, for some reason I'm having trouble selecting the V direction.
                              (Especially if I try to click on an outer edge.)
                              Usually, selecting the U direction works.
                              Then for V it doesnt select what I'm clicking on. πŸ˜•
                              When I click the edge on the other side of the selected U edge, "mirrored from the first", it works more often, but the texture isn't applied as I would like. 😞
                              I'm having this problem with every model I tried.
                              SU 8, Windows 7 64.
                              • dereiD
                                derei
                                Hello, I noticed a error when opening a a second SU instance (if I have one already opened and I want a second one), you can see it here.
                                Thank you.
                                DESIGNER AND ARTIST DEREI.UK
                                  SU 8, Windows 7 64.
                                  Screenshots? Video?
                                    Thank you.
                                    Does that happen every time?
                                    After you've gotten such an error, what do you get if you open the Ruby Console and type load 'tt_quadface.rb'?
                                      Here's a little library of 10 UV maps.
                                      UV Map .skm Library
                                      Here's the pretty one you like...
                                      • dereiD
                                        derei
                                        It does every time.
                                        If I load it from console, it happens this:
                                          Thanks - will look into it.
                                          • cmeedC
                                            cmeed
                                            great to see a video and what amazing work you put into this forum. really well done.
                                            I'm trying this out for the first time and am having some trouble, the problem is that i can put a texture in but then cant change it to a new one
                                            Its basically only works once and you can't map anything else to that shape. or i've missed something. - I'm on a mac
                                            (suggestion - is there a roll over help pop up that can be used that when you leave the curser ove an icon a pop up help describes the function?)
                                            • 33
                                            • 34
                                            • 4 / 34
