    [Plugin] QuadFaceTools
    680 Posts 116 Posters 699.7k Views 116 Watching
      Just need an icon...
        Version 0.11.0 is out.
        • N Offline
          numerobis
          😎 πŸ‘
          • cottyC Offline
            cotty
            πŸ‘ and πŸ‘
            my SketchUp gallery
            • pbacotP Offline
              Nice!
              • ithilI Offline
                ithil
                Very cool!!!
                Thank you! πŸ‘
                • plot-parisP Offline
                  plot-paris
                  Working nicely! Very valuable tool for quick and clean quad face modelling.
                  Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis?
                  That would show clearly, if the system is switched on or off.
                    hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either.
                    Logged in issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
                      Carto
                      Hello ThomThom,
                      I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
                      Regards
                        Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
                          Carto
                          Hello ThomThom,
                          See attached model. I have the latest version 0.11.0
                          UV_Example.skp
                            Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
                              Carto
                              Hello ThomThom,
                              Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
                              Regards
                                Version 0.12.0
                                • Made OBJ importer create groups from OBJ groups.
                                • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                                  Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                                  http://www.realtimerendering.com/erich/minecraft/public/mineways/
                                  • eneroth3E Offline
                                    eneroth3
                                    This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                                    https://3dwarehouse.sketchup.com/model.html?id=9722740f-15f5-49df-a12b-5f3d3de85f27
                                    My website: http://julia-christina-eneroth.se/
                                    • K Offline
                                      kaas
                                      Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                                        Got a sample model? Screenshot?
                                        • K Offline
                                          kaas
                                          Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                                            Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                                            That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                                            Also, what version of the extension do you have?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
