    [Plugin] QuadFaceTools
    680 Posts 116 Posters 594.1k Views 116 Watching
    • john2J Offline
      john2
      @thomthom said:
      All my extensions should have a single root rb as well as a folder with the same name of the rb file. So there shouldn't be many files to remove.
      Thanks! I installed all your plugins again, deleted files of old ones. Now I'm free from errors πŸ˜„
      • john2J Offline
        john2
          Excellent! πŸ˜„
          • john2J Offline
            john2
            @thomthom said:
            Excellent! πŸ˜„
            πŸ‘
            • john2J Offline
              john2
              Can these tools somehow used to solve the problem I'm facing here?
              http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=57167%26amp;p=520075#p520075
              • romboutR Offline
                rombout
                How does the blender quads to sketchup quads work, when i press the Suzanne (monkey) icon nothing happens?
                  It's for converting imported geometry to Quads. When exporting geometry to blender and importing into SketchUp the edge that split the triangles in a non-planar quad is hidden - this function convert it to work with QuadFace Tools.
                  https://bitbucket.org/thomthom/quadface-tools/wiki/Features#!convert-blender-quads-to-quadface-quads
                  • Rich O BrienR Online
                    When Blender to Quads fails you can also try using selection toys to select faces and hidden lines. Delete them and then run wireframe to Quads
                      When does it fail? 😲
                        By fail I mean the mesh generated is not what you had in blender.
                        Tons of reversed faces and duplicate faces.
                        • G Offline
                          gamophyte
                          I am a noob at uv mapping but know SU pretty well. I simply wanted a texture to wrap around the outer lamp shade, I am building for a game.
                          No matter how many times I try, I can't seem to get the materiel on the outside of the shade (I selected out from the rest of the model). It keeps appearing on the inside. I realized that selecting faces outside is also selecting faces inside. I know I can make the shade thicker but I need it to be one poly thick to keep polys down.
                          http://i.imgur.com/ZpGq2CW.png
                          Is there a way to do this?
                          THANKS!
                            The 'fronts' of those faces are probably oriented so that they facing 'inwards'.
                            Faces have backs and fronts...
                            Change the default back face color in the Style to be distinctive from the front color [say bright blue v off-white] and then View in Monochrome mode...
                            You'll see what is wrong...
                            To fix reversed faces select the faces that are wrongly oriented [a dragged fence will make a multiple selection, hold Ctrl to add to a selection] - then use the context-menu 'Reverse', and the faces will flip over to be correctly arranged...
                            The similar tool 'Orient' will make all faces connected to the selected one face to have the same orientation - it might cause issues if an edge is shared by more than two faces as then you can never get them all to share the same orientation...
                            • G Offline
                              gamophyte
                              It was just as you said. I guess it became that way when I did the fallowme tool to make my lamp from a cross section. I actually fixed it by selecting whole shade without worry of selecting certain faces.
                              I'm golden now, thanks so much!
                              EDIT: is there a way to then do quadface on the other side? I want to do just have the diamond black frame of the texture on the back. Do I just reverse faces again?
                              • G Offline
                                gamophyte
                                It looks like this method won't work for my game design. I thought the textures where placed not duplicated to make it work.
                                http://i.imgur.com/xCh4Jjh.png
                                If I made this lamp by straight applying and positioning materials on faces the export 3ds would only be four materials (four pngs to put in my game assets folder). Using this way, well.. the screenshot. I can't have hundreds of the same texture.
                                Is there a way around this? Have texture alignment coordinates instead of multiple textures?
                                • tt_suT Offline
                                  tt_su
                                  You can use my "UV Toolkit" extension to transfer UV mapping between front and back side of faces.
                                  • Le Quoc HungL Offline
                                    Le Quoc Hung
                                    A question: Is there a way to chamfer quad faces? Look like that :
                                    302 Found
                                    (www.mariussilaghi.com)
                                      Hmm... I wonder if Fredo's RoundCorner extensions support quads? I know a few of this extensions support quad faces like QuadFaceTools'.
                                      • K Offline
                                        Kristusea
                                        How would i go about texturing this? When i select the road part it only textures those 2 faces and when i select the sidewalk it doesn't work at all. Am i doing something wrong?
                                        • pbacotP Offline
                                          Turn off hidden geometry to select whole surfaces.
                                          • K Offline
                                            Kristusea
                                            I did select the whole surface but that's all it paints.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
