    [Plugin] Shell
    93 Posts 33 Posters 69.8k Views 34 Watching
      Overview
      Result of a work in progress test for another plugin I'm working on. It adds thickness to the surface inside selected groups and components.
      Where is differs from Joint Push Pull is that it works on selected groups and components only. A group is added inside the group/component which will contain the shell. It generally seem to work faster than JPP, but it's tested far less and might very well break.
      Usage
      1. Select groups and/or components.
      2. Activate Shell from the Tools menu.
      3. Enter a thickness in the VCB or pick a distance in the model.
      4. Double-click to commit. (You can also use Return to commit as long as the thickness has not changed.)
      BitBucket
      The project is available on BitBucket so if anyone wants to add improvements they can join the project and submit their changes.
      https://bitbucket.org/thomthom/shell/wiki/Home
      Access
      Tools > Shell
      Requirements
      • SketchUp 8 or newer - ( Other versions untested )
      • TT_Lib2 (v2.5.4)
      404 Not Found
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_shell.rb
      http://forums.sketchucation.com/download/file.php?id=53761
        Nom nom nom πŸ‘
        http://www.thearender.com/forum/download/file.php?id=8668
          Rich, I think that a 1.6MB cookie image is warrant for a ban...
            OK, I'll ban you later πŸ‘
              I expect a cookie in 1:1 scale to that photo in my mail
              • EarthMoverE Offline
                EarthMover
                Looks interesting. Thanks Thom! πŸ‘
                Content Creator at Skapeup
                • utilerU Offline
                  utiler
                  You're da bomb, Thom!!!!
                  Have been feeling for your countrymen of late, mate.... πŸ‘
                  Just Curious...
                    driven
                    hi Thomas,
                    would it be ok to change the menu name to 'tt_shell' as it needs to be unique to use a mac system shortcut key and Jim's simple shell uses 'shell' in the SU menu already...
                    it also turned off all my other toolbars [except 'booleen helper' and SU ones] when I first loaded/ran it.
                    never had that happen before...
                    I'll do some testing tonight.
                    john
                      You can edit line 40 to change the menu name.
                      There is nothing in the plugin's code that modifies other toolbars. It doesn't even add one itself.
                      Did it cause any errors when you loaded the first time?
                        driven
                        yes,
                        it failed on one particular group and generated error messages, so I'd make something less something less complex, but I noticed all my toolbars had gone.
                        I turned the same ones back on restarted SU, used tt_shell again and they were fine...
                        I get non planar faces errors on things that JPP works on.
                        I'll have a proper look later
                        john
                          Can you give me a sample model?
                            driven
                            hi thomas,
                            here's something similar that fails tt_skin, but works for JPP.
                            the lavender one is jpp'd.
                            Also, the disappearing toolbars are from TIG's new DAE exporter, which uses
                            Sketchup.send_action('terminate:')
                            which 'disappears' the toolbars and was the last thing that I had used before I installed this.
                            john
                            tt_skin_test.skp
                              Cheers for the model!
                              • StinkieS Offline
                                Stinkie
                                πŸ˜†
                                Thanks, Thomas!
                                • N Offline
                                  nomeradona
                                  this is the one im waiting for. I requested for this before but many keep on pointing joint push pull. thanks thomas..
                                  visit my blog: http://www.nomeradona.blogspot.com
                                    jorge2011
                                    Hi thom, This plugin generates a small error, you can fix that
                                    Error: #<ArgumentError: Points are not planar>
                                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:370:in shell'
                                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:362:in shell'
                                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:321:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in each'
                                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:319:in offset_mesh' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:173:in onReturn'
                                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/tt_shell.rb:420
                                    • jeff hammondJ Offline
                                      jeff hammond
                                      wow 😲
                                      i missed this one..
                                      gonna test it a little later tonight.
                                      thanks thom
                                      dotdotdot
                                        Ah, yea. There are bugs in this plugin. Hence the Alpha status of the version number. Though I've not had any time to work on it recently.
                                          robert111
                                          mr thomthom
                                          when i make group for this form , i and i use shell plugin , i have this stroange message
                                            That error message is not something I've put into Shell. I have no idea where it's coming from. Exactly what is the steps you do to produce that? (Can you also share the model along with the steps?)
                                            • 1 / 5
