    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 244.3k Views 51 Watching
      Jim
      Mike, if you are attempting to include the full Ruby language in SketchUp then this is not the way to go. You need to use the same Ruby version as SketchUp for the compiled libraries (.so files) for binary compatibility.
      see this thread:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=29412
        If you are not using the '000_AdditionalPluginFolders' folder for your scripts then why not uninstall its .rb ?
        Without it do these errors still occur ?
        As Jim said, do you have any other Ruby stuff auto-installing ?
        If so read the guidance he's linked to ...
        • 2 Offline
          26delta
          see this thread:
          I've already responded to the other topic with the exact error message. I had to remove windows.rb due to failure to locate parametric.rb in order to define the Window superclass. It's beginning to look like a load sequence error in which certain required ruby scripts are loaded before they are required and then report as a failure to load because they are already loaded.
            The file windows.rb uses
            require 'parametric.rb'
            which loads the parametric methods UNLESS it has already loaded earlier.
            Considering they load in alphanumeric order, and 'p' comes before 'w'. the ' require' is unlikely to do anything...
            However, your error message suggests that parametric.rb cannot be found [the proper full message rather than your prรฉcis would help].
            If it is indeed in the same folder as windows.rb, this is odd...
            You say they are both in Plugins ?
            However, newer versions of Windows can have annoying protective tricks - if you don't have FULL security access rights to the Plugins folder it will let you think that you have installed the files correctly, but there might be an extra button on the top bars of the folder's window saying something like 'Compatibility Files...' - this then opens the true home of the files.
            So a possibility is that ' parametric.rb' is not actually inside the Plugins folder and therefore the ' require' [and/or 'auto-load'], that would be done using one of the $LOAD_PATH folders, can't find it ๐Ÿ˜’
            Please check this out and report back... ๐Ÿ˜•
            • 2 Offline
              26delta
              The problems with this plugin have been resolved. The culprit was the Rayelectron rendering package which contains a renamed Win32API.so file ('Win32API.so' vs 'win32api.so'). Now, onto the next problem...
              The windows.rb has problems with defining 'Window' as a superclass. Given that this is one of the original Sketchup ruby scripts, who's responsible for maintaining it?
                arnozsofi
                Hi, I just put the content in the plugins folder, but nothing happened. Enyone can help me out?
                  matt.gordon320
                  Hi guys,
                  I've been having an issue with 000_AdditionalPluginFolders ever since I installed the Developer Tools Plugins that were announced at Base Camp 2012. Is anybody else having this following issue?
                  PLUGIN: testuprunner.rb
                  FOLDER: C:/Program Files/Google/Google SketchUp 8/Plugins/sketchup-developer-tools/testup/ruby
                  ERROR: No such file or directory - test_cases.man
                  I've visited the Developer Tool subfolder, but I can't really figure out what's missing.
                  Let me know if that isn't enough info!
                  Thanks Gents,
                  Matt
                    driven
                    hi,
                    the file is created at runtime, so is missing until you use it.
                    it should work even after the warning,
                    alternatively, put dev tools in the 'Tools' folder and avoid the error message when you use additional plugins loader.
                    john
                      Bobane
                      thanx
                      • V Offline
                        veerlexyz
                        Fredo,
                        This plugin does'nt work anymore after Sketchup's update today 11/1/2013 (Layout asked for it). The ruby is still in the normal plugin-folder but not vissible in the Window-menu.
                        How to solve this? Thanks a lot!
                        • V Offline
                          veerlexyz
                          Problem solved after restarting pc. Sorry...
                            matt.gordon320
                            @matt.gordon320 said:
                            Hi guys,
                            Thanks Gents,
                            Matt
                            Hey guys, I'm still having trouble wrapping my head around how to get this error to go away. I've run every test I can in TestUp (that I know how at this point), but I still get this error on every start. I've had no difference when I've placed the Developer Tools into the tools folder.
                            Any thoughts?
                            Thanks, Matt
                            • fredo6F Offline
                              fredo6
                              NEW RELEASE 3.1a - 29 Jan 2013
                              Major Fix of issues related to loading RBS scripts:
                              This update fixes problems related to loading certain rbs files (scrambled scripts) such as OSCoolean.
                              Thanks to Thomthom and Dan Rathbun for providing a diagnosis and a solution.
                              It is strongly advised to upgrade.
                              See first post of this thread for downloading the script.
                                addy
                                How about design a "Loader" ?
                                Launch a menu and shift the plugin folder to the one you need then load SU...
                                • fredo6F Offline
                                  fredo6
                                  I think you have the standard Plugin extensions for that.
                                  Fredo
                                    addy
                                    Sorry for my poor Englsh ...
                                    Because I hope I can divide my work into some sessions: modeling,texturing, rendering ...etc
                                    I am thinking if we can make a "standard plugin" each time that contains only the plugins we need before we launch SU.
                                    Actually I am doing this by a batch file now (I know the interface is ugly):
                                    \Google SketchUp 8\Plugins
                                    \plugins_modeling
                                    \plugins_texturing
                                    \plugins_vray
                                    \plugins_test
                                    ------------------- .....etc
                                    for example, if I need to do a render work,
                                    I run the batch file to rename "plugins" to "plugins_00"
                                    and rename "plugins_vray" to "plugins"
                                    and call Sketchup.exe
                                    after the work, I leave SU, the folder will rename back.
                                    I know that is not a ruby issue, but I think maybe it's not a bad idea .. ๐Ÿ˜„
                                    Addy
                                      matt.gordon320
                                      Hey guys, I could use some advice. I removed all my plugins from my folder because I'm reinstalling all of them from scratch (I'm having something create a bunch of help menus and can't pin down the problem). However, after I've removed all plugins from the plugins folder, I still get missing plugin warnings from 000_AdditionalPlugins - even though I don't use it or have it installed on my system. Any idea what's going on?
                                        I'm going to guess you're using Windows (Could you please fill out your profile with SU version and OS?) and that you're running into problems with Virtual Store.
                                        Have a look at this utility to help you locate files that's strayed into Virtual Store: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                                          matt.gordon320
                                          I will both update my info (apologies) and try that. Thank you sir! I'll get back to you.
                                          EDIT Ok, it looks like there's a whole bunch of plugins that I had removed saved to the Virtual Store. I'm guessing I need to purge that file, and then re-install the plugins I'm going to use?
                                            Yea, Windows will place files in Virtual Store when you have UAC enabled, I think. I don't have this issue, but I'm running as administrator with UAC disabled because I muck about the system a lot when programming. It's not recommended for regular users to do so.
                                            Instead give yourself full access to the Plugins folder.
                                            When you look in a folder and some files have ended up in Virtual Store there should be a "Compatibility Files" button that does pretty much the same as that utility I linked to.
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
