    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 258.8k Views 51 Watching
      gabegabe
      I've installed this beautiful 000_AdditionalPluginFolders (v3.0a - 23 Aug 11)
      I have some compatibility problems with SU Podium Rendering Plugin
      Windows 7 64bit:
      When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is NOT loaded;
      When I remove 000_AdditionalPluginFolders.rb into Google Sketchup Plugin FOLDER, SU Podium is regulary loaded
      Windows XP 32bit:
      When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is loaded, EXEPT Pobium Browser;
      Mac OSX Lion:
      When I put 000_AdditionalPluginFolders.rb in Google Sketchup Plugin FOLDER, SU Podium is loaded, EXEPT Pobium Browser and I receive a LOG error message;
      Any suggestions?
      Thank You
      • JQLJ Offline
        JQL
        Thanks Fredo for this very useful plugin.
        I've noticed something strange though:
        I have created two folders outside the program files directory:
        Original Folder - is the standard plugin's folder and had only your plugin.
        Folder 1 - has all my plugins
        Folder 2 - has the plugins I am testing and may delete
        I noticed the projections_v2 plugin was not working although it displayed all the icons on the toolbar. It was the only one. I moved it to the Original Folder with its tassociated folder (wich in this case had the .png icon files and a .rbs). When I did that the plugin started working but all the icons were gone from the toolbar. I copied the icon files from the Original Folder to Folder 1, keeping the same file struture. Everything is correct now.
        I noticed the same thing happening to another plugin that I was testing and was in Folder 2, (pointool.rb) but this does not happen to all plugins.
        Is it possible that Sketchup is assuming that Folder 1 is the main plugin folder? Is it possible that there are multiple ways of assigning paths inside plugins and some of those ways are causing those errors?
        For me the problem no longer exists, but it may interest you. Thanks again and best regards.
        www.casca.pt
        Visit us on facebook!
        • 2 Offline
          26delta
          Ever since installing 000_AdditionalPlugiFolders, I have been getting error messages regarding win32api.so and the windows.rb and parameter.rb files. The first indicates that the procedure Init_win32api cannot be found in win32api.so.
          As far as I know, that procedure has never existed. The second error message indicates that the windows.rb cannot find the parameters.rb file and the third error message repeats the first. I'm at a loss.
          • TIGT Online
            If you move scripts [.rb/.rbs files] - and their subfolders of supporting files etc - out of the main Sketchup Plugins folder into another folder that has been added onto the $LOAD_PATH list [as with "000_AdditionalPluginFolders"], then they will still load/work OK, as they will auto-load like they used to from the main Sketchup Plugins folder.
            However, if the scripts ' require' some other file[s] to be preloaded [like 'parameters.rb' or 'win32api.so'] then any 'required' files also have to be in a folder included in $LOAD_PATH too. If it's not then you'll get a 'load error'.
            The windows.rb has the line at it's start
            require 'parametric.rb'
            to ensure that the methods available from that code are available to the 'windows' code...
            You might also see that it has
            require 'sketchup.rb'
            but as that must always to be kept in the Sketchup 'Tools' folder, with other 'system' files, and that particular folder is automatically added to the $LOAD_PATH list, then there are no errors about that.
            So it expects a 'required' file to be somewhere in the folders listed in $LOAD_PATH.
            If the file is missing you get the error messages.
            The missing 'parametric' file is available here http://sketchup.google.com/intl/en/download/rubyscripts.html
            Some '.so' files are available here... http://forums.sketchucation.com/viewtopic.php?p=380121#p380121
            Also note that some scripts might try to find/use files passing an exact path using say
            load(Sketchup.find_support_file("argh.rb", "Plugins"))
            where this method will always look for that file in the Sketchup Plugins folder, irrespective of where the script that's looking for it might now be located, so moving any related files over with the script will fail to get the desired files/code loaded if it hasn't been left in Plugins.
            This is particularly limiting if the script's supporting files are in a subfolder with a path that's hard-code to be always in Sketchup's Plugins folder using this method - relocating the subfolder will then fail to load then files properly.
            If the desired file is always to be kept with the script that's looking for it, then a safer option in the coding is to use
            load(File.join(File.dirname(__FILE__), "argh.rb"))
            as this is then looking in the actual script's folder [whatever that might be] for that desired support file.
            • 2 Offline
              26delta
              That's the rub. The .rb files ARE in the default Plugins folder.
              The major problem reported in errors 1 and 3 is that there is reference to a procedure 'Init_win32api' which (according to the Win32api.rdoc) does not exist. This may be causing the failure to recognize parameters.rb in error 2. I have reloaded Sketchup and the plugins to no avail.
                Jim
                Mike, if you are attempting to include the full Ruby language in SketchUp then this is not the way to go. You need to use the same Ruby version as SketchUp for the compiled libraries (.so files) for binary compatibility.
                see this thread:
                404 Not Found
                (forums.sketchucation.com)
                • TIGT Online
                  If you are not using the '000_AdditionalPluginFolders' folder for your scripts then why not uninstall its .rb ?
                  Without it do these errors still occur ?
                  As Jim said, do you have any other Ruby stuff auto-installing ?
                  If so read the guidance he's linked to ...
                  • 2 Offline
                    26delta
                    see this thread:
                    404 Not Found
                    I've already responded to the other topic with the exact error message. I had to remove windows.rb due to failure to locate parametric.rb in order to define the Window superclass. It's beginning to look like a load sequence error in which certain required ruby scripts are loaded before they are required and then report as a failure to load because they are already loaded.
                    • TIGT Online
                      The file windows.rb uses
                      which loads the parametric methods UNLESS it has already loaded earlier.
                      Considering they load in alphanumeric order, and 'p' comes before 'w'. the ' require' is unlikely to do anything...
                      However, your error message suggests that parametric.rb cannot be found [the proper full message rather than your précis would help].
                      If it is indeed in the same folder as windows.rb, this is odd...
                      You say they are both in Plugins ?
                      However, newer versions of Windows can have annoying protective tricks - if you don't have FULL security access rights to the Plugins folder it will let you think that you have installed the files correctly, but there might be an extra button on the top bars of the folder's window saying something like 'Compatibility Files...' - this then opens the true home of the files.
                      So a possibility is that ' parametric.rb' is not actually inside the Plugins folder and therefore the ' require' [and/or 'auto-load'], that would be done using one of the $LOAD_PATH folders, can't find it 😒
                      Please check this out and report back... 😕
                      • 2 Offline
                        26delta
                        The problems with this plugin have been resolved. The culprit was the Rayelectron rendering package which contains a renamed Win32API.so file ('Win32API.so' vs 'win32api.so'). Now, onto the next problem...
                        The windows.rb has problems with defining 'Window' as a superclass. Given that this is one of the original Sketchup ruby scripts, who's responsible for maintaining it?
                          arnozsofi
                          Hi, I just put the content in the plugins folder, but nothing happened. Enyone can help me out?
                            matt.gordon320
                            Hi guys,
                            I've been having an issue with 000_AdditionalPluginFolders ever since I installed the Developer Tools Plugins that were announced at Base Camp 2012. Is anybody else having this following issue?
                            PLUGIN: testuprunner.rb
                            FOLDER: C:/Program Files/Google/Google SketchUp 8/Plugins/sketchup-developer-tools/testup/ruby
                            ERROR: No such file or directory - test_cases.man
                            I've visited the Developer Tool subfolder, but I can't really figure out what's missing.
                            Let me know if that isn't enough info!
                            Thanks Gents,
                            Matt
                              driven
                              hi,
                              the file is created at runtime, so is missing until you use it.
                              it should work even after the warning,
                              alternatively, put dev tools in the 'Tools' folder and avoid the error message when you use additional plugins loader.
                                Bobane
                                thanx
                                • V Offline
                                  veerlexyz
                                  Fredo,
                                  This plugin does'nt work anymore after Sketchup's update today 11/1/2013 (Layout asked for it). The ruby is still in the normal plugin-folder but not vissible in the Window-menu.
                                  How to solve this? Thanks a lot!
                                  • V Offline
                                    veerlexyz
                                    Problem solved after restarting pc. Sorry...
                                      matt.gordon320
                                      @matt.gordon320 said:
                                      Hi guys,
                                      Thanks Gents,
                                      Matt
                                      Hey guys, I'm still having trouble wrapping my head around how to get this error to go away. I've run every test I can in TestUp (that I know how at this point), but I still get this error on every start. I've had no difference when I've placed the Developer Tools into the tools folder.
                                      Any thoughts?
                                      Thanks, Matt
                                      • fredo6F Offline
                                        NEW RELEASE 3.1a - 29 Jan 2013
                                        Major Fix of issues related to loading RBS scripts:
                                        This update fixes problems related to loading certain rbs files (scrambled scripts) such as OSCoolean.
                                        Thanks to Thomthom and Dan Rathbun for providing a diagnosis and a solution.
                                        It is strongly advised to upgrade.
                                        See first post of this thread for downloading the script.
                                          addy
                                          How about design a "Loader" ?
                                          Launch a menu and shift the plugin folder to the one you need then load SU...
                                          • fredo6F Offline
                                            I think you have the standard Plugin extensions for that.
                                            • 3 / 8
