    Kzx to skp
    extensions
    12 Posts 5 Posters 4.0k Views 5 Watching
    • 3 Offline
      3DModellers
      can anybody tell me how to convert kerkythea's models (kzx format )to sketchup
      regards
      Pritam
        Kzx is actually a renamed zip file. Change the extension to ZIP and unpack the archive. You will find an XML file inside. This file can be converted by this tool (it says - I have not tried):
        http://web.axelero.hu/karpo/
        Ask about the converter on the Kerkythea forums
        • massimoM Offline
          massimo Moderator
          You can also use this nice application http://www.nicetuna.com/kt2obj to directly convert .xml/.kzx files to obj. Then you need a plugin to import the obj in SU. Here are a couple:
          http://forums.sketchucation.com/viewtopic.php?p=172790#p172790
          http://forums.sketchucation.com/viewtopic.php?f=80&t=35936&hilit=fluid+importer
          • 3 Offline
            3DModellers
            thanks Massimo and Gaieus.
            The tool can easily convert xml/kzx to obj. But the obj importer in sketchup is a trouble as it takes ages to import small models. Mostly it crashes. Whenever it imports, it also loses all the textures.
            I am using sketchup for modeling and kerky for rendering. KT has a great library of 3D plants and landscaping material. but I find it very difficult to move the models around in KT.
            Is it possible to import KT xml files into sketchup. even this wud solve my problem. Or is there any better way to handle plant models in KT.
            • FrederikF Offline
              Frederik
              First of all I'd like to say that if you succeed importing i.e. one of the KT Xfrog trees to SU, I'm sure you'll learn that they're almost impossible to handle in SU...
              SU is well know for it's limitations on poly heavy models, so be prepared... πŸ˜„
              What models are you refering to, cause like I said above, if it's one of the Xfrog trees, they are available in other file formats, which - in principle - should be possible to import to SU... πŸ˜„
              Sorry... It's not possible... 😐
              Well... You haven't told us anything about how you handle it today, so difficult to say if there's a better way... πŸ˜‰
              Any way... I really don't understand why you find these models difficult to handle (I assume you mean position...?) in KT...
              If you group them and use the gizmo, they can easily be positioned anywhere in your model in KT...
              Or take a look at the tutorial I wrote many moons ago from the Replace your instance with KT instance object (proxy,almost) thread... πŸ˜„
              Cheers
              Kim Frederik
              • 3 Offline
                3DModellers
                Thanks Freidreik,
                that tutorial was lot of help. I successfully replaced many trees. Since the widths of the original trees and new trees are different , lot of empty spaces are created between the new trees now. I would like to just copy a tree and paste it wherever I want. Is that possible in KT(copy, move and paste.)
                I started using KT since last Wednesday. Kt gives great results and has great library of materials and models. bad for me that I am not able to navigate . A lot of my problems in KT are because I was used to the ease of sketchup. πŸ˜„
                pritam
                • FrederikF Offline
                  Frederik
                  Yes... The easiest way is using the instancing brush... πŸ˜„
                  I recommend that you take a look at the Instancing tutorial...
                  Perhaps you're just aiming a little too high... πŸ˜‰
                  As a beginner you should check out as many of the tutorials available and learn the application step by step...
                  As the saying goes... Rome wasn't build in a day...
                  Cheers
                  Kim Frederik
                  • N Offline
                    notareal
                    pritam
                    Priority in KT where never in modelling tasks. Although it does have some manipulation features... they mostly meant for simple tasks, like adding some KK object to a approximated location. For accurate locating you will need a different strategy; proxies (for accurate model positioning via the modelling app) and instancing brush if you need to add plenty of copies of a object (you need to define areas in modelling app).
                    • 3 Offline
                      3DModellers
                      Thanks everybody. I was able to get some good outputs.
                      • 3 Offline
                        3DModellers
                        Hi , I took this attached render in KT with following settings.
                        PhotonMap Fine AA +0.3
                        I used all KT original materials. What am I doing wrong here?
                        • FrederikF Offline
                          Frederik
                          You need to project the textures to get proper UV mapping...
                          Cheers
                          Kim Frederik
                            Yes, the SU2KT exporter will export all UV co-ordinates you assigned in SU. If these are missing, it is really hard to get materials properly mapped in KT (there are some basic UV mapping tools there but you can only map by material - which means everything with that material.)
