    [Tutorial] DR Spawner V-ray 1.49.01
    renderpluginsextensions
    41 Posts 20 Posters 25.1k Views 20 Watching
    • rodrigonotorR Offline
      rodrigonotor
      Some days ago Viztecture post some questions about DR Spawner in this topic: http://forums.sketchucation.com/viewtopic.php?f=322&t=38848#p343099
      I try to make a tiny guide to explain the process.
      Sorry about my English but is not my native language
      Firs of all, you have to connect yours PCs in a LAN (Local Area Network) and know what IP address have each one. By default Windows OS come with DHCP activated, which mean it's the hub that assign the IP address for each pc.
      In my case, for practical reason I make my LAN with static IPs. The default IP address is 192.168.xx.xx. I use another because I manually assign IP address to a specific PC. I use 172.16.25.xx
      Ok, going back to IPs issue, to know what is the IP address of each PC, in the windows star menu, choose run and then CMD. A window like this should be appearing:
      http://img20.imageshack.us/img20/8890/19062011125919pm.jpg
      Inside the DOS windows, you have to type ipconfig and then key enter o intro and look like this
      http://img10.imageshack.us/img10/2743/19062011010434pm.jpg
      In my case, my IP address is 172.16.25.7 this can be done in each PC that you want to connect whit DR Spawner
      Second important thing, probably you have installed V-ray without Distributed Rendering Spawner, again run the installer an choose only the DR Spawner option.
      http://img546.imageshack.us/img546/4115/19062011011025pm.jpg
      Once the DR Spawner is installed in each PC you have to run, in theory is in the Windows start->Programs->V-ray for Sketchup->Distributed Rendering Spawner. When you run the DR Spawner a window like this should appear
      http://img90.imageshack.us/img90/6324/19062011011421pm.jpg
      Don`t close that window.
      Third important thing, you have to set permissions in the windows firewall
      http://img405.imageshack.us/img405/3091/19062011012216pm.jpg
      Ok, almost done, to make sure that the Master is connecting to other PCs run CMD again and type (in my LAN is) ping 172.16.25.xx -t where xx is the number or numbers assign to each PCs
      http://img862.imageshack.us/img862/8208/19062011012744pm.jpg
      Now the LAN is ready to make a Distributed render
      In V-ray Options->System check box ON and then click to the button with 3 points
      http://img835.imageshack.us/img835/8519/19062011014210pm.jpg
      also check the box "Asset Collection" and "Send to each node"
      http://img805.imageshack.us/img805/7018/23102011064528pm.jpg
      Here is for config the hosts (slaves) add server write the IP address and OK
      http://img685.imageshack.us/img685/8536/19062011014945pm.jpg
      Entered all hosts or servers, click on the button resolve servers and check the IP addresses that we have entered.
      http://img805.imageshack.us/img805/8400/19062011015239pm.jpg
      Check box each server
      http://img339.imageshack.us/img339/7171/19062011015855pm.jpg
      And done, Distributed Rendering Spawner it's configured.
      Distributed Rendering Spawner Off
      http://img17.imageshack.us/img17/5463/19062011020520pm.jpg
      Distributed Rendering Spawner On At the begin
      http://img232.imageshack.us/img232/1843/19062011020846pm.jpg
      Distributed Rendering Spawner On in the process
      http://img805.imageshack.us/img805/251/19062011021009pm.jpg
      Distributed Rendering Spawner On almost finished
      http://img830.imageshack.us/img830/3706/19062011021447pm.jpg
      Saludos (Regards)
      • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
      • P Offline
        pepa
        Many thanks for your nice tutorial..😄
        http://jsvizualizace.daportfolio.com/
          rodrigonotor
          Your Welcome.
          Also in spanish to: http://forums.sketchucation.com/viewtopic.php?f=52&t=38922#p343682
          • N Offline
            nomeradona
            very nice.. i do not know anything with DR Spawner
            visit my blog: http://www.nomeradona.blogspot.com
              rodrigonotor
              Another image, I connect 5 PCs, the maximum number of PCs that can connect is 10
              http://img263.imageshack.us/img263/2395/10072011054201pm.jpg
                radiosity-renders
                hola Rodrigonotor magnifica tu explicacion puede conectar el drspawer, el problema que tengo es que el esclavo no lee las texturas de la carpeta compartida, podrias explicar como hacer esto?
                muchas gracias de antemano
                saludos
                https://www.facebook.com/radiosityrenders
                  rodrigonotor
                  Hola Radiosity, prueba con estas opciones marcadas.
                  Hi Radiosity, try with checking this options.
                  Saludos
                    radiosity-renders
                    hola rodrigo gracias por tu respuesta, funciona perfectamente, era tan simple como marcar esa opcion, yo marcaba send to shared folder y mandaba las texturas a una carpeta en red, y no habia caso....
                    muchas gracias nuevamente fue de mucha ayuda tu tutorial
                    saludos desde Argentina!
                      rodrigonotor
                      No hay de que, es un gusto poder haberte ayudado.
                      Saludos
                      • - Offline
                        -rb-
                        Anyone have problems with this on OSX? Chaos don't seem to be getting back to me!
                          rspierenburg
                          Does anyone else notice that DRSpawner is using massive amounts of CPU power? I have it installed on two dual-core computers and its taking up 50% of the CPU resources on each. Just wondering if this is by design or is it a bug.
                            Yes, it's exactly what it should be doing - making use of your CPU to render.
                              rspierenburg
                              But that is without a render being started. I figured it would run idle until Vray calls upon it to start rendering. I figured I could leave it running on the slave computers but it seems like a lot of cpu strain for no reason. 😛
                              Rob
                                That ... is not normal... I have not seen that behaviour. I'd recommend you contact ASGVis Support.
                                  Ugh.. I mean ChaosGroup USA - which is their new name. I can't get used to the change of name. 😒
                                  • eidam655E Offline
                                    eidam655
                                    i have EXACTLY this issue.
                                    i even posted about it on the old ASGVis forum, before it got changed to chaosgroup...
                                    (this is mine, but i can't find the asgvis forum link anymore (surprisingly))
                                    if anyone had any idea, about what's going on, i (we) would be glad.
                                    rspierenburg, what OS and CPU do you have? i have the same issue with a 32bit Vista with Intel C2D SL9400 and 64bit Win7 with Intel C2D E8400. or is it maybe with the installation? (1.49.01)
                                    I'm using SketchUp 2017, V-Ray 3.4
                                      j40
                                      Rodrigo, Thank you ! for that great tutorial. I've cut the render time in half 😍
                                      Top3D Studio
                                        rodrigonotor
                                        Your welcome, How many computers are you connecting?
                                          j40
                                          I connected with a LAN cable a notebook (4 cores) to my MacBook Pro (2 cores).
                                          I don't know if it should be like that, but the second pc kicks in only in the rendering phase, meaning that in the LC calculating phase it's only my main pc working.
                                          Oh, and I did have some problem with the textured geometry, that came out rendered as solid color. It took me a while to figure out that all it takes is to check the "Asset Collection" box. Maybe you could add that to the tutorial.
                                          btw is it better to use LAN connection rather wifi?
                                          Top3D Studio
                                            rodrigonotor
                                            Added "asset collection" settings to the tutorial.
                                            That depends on your wireless connection, if you have the same speed as your wired connection is the same thing. If not, the wired connection, most of the times is much faster than the WI-FI connection.
                                            Regards
                                            • 1 / 3
