    [Tutorial] DR Spawner V-ray 1.49.01
    renderpluginsextensions
    41 Posts 20 Posters 26.6k Views 20 Watching
      radiosity-renders
      hola Rodrigonotor magnifica tu explicacion puede conectar el drspawer, el problema que tengo es que el esclavo no lee las texturas de la carpeta compartida, podrias explicar como hacer esto?
      muchas gracias de antemano
      saludos
      https://www.facebook.com/radiosityrenders
      • rodrigonotorR
        rodrigonotor
        Hola Radiosity, prueba con estas opciones marcadas.
        Hi Radiosity, try with checking this options.
        Saludos
        http://img805.imageshack.us/img805/7018/23102011064528pm.jpg
        • Sketchando.net • www.arqcad.net •
          radiosity-renders
          hola rodrigo gracias por tu respuesta, funciona perfectamente, era tan simple como marcar esa opcion, yo marcaba send to shared folder y mandaba las texturas a una carpeta en red, y no habia caso....
          muchas gracias nuevamente fue de mucha ayuda tu tutorial
          saludos desde Argentina!
          • rodrigonotorR
            rodrigonotor
            No hay de que, es un gusto poder haberte ayudado.
            Saludos
              -rb-
              Anyone have problems with this on OSX? Chaos don't seem to be getting back to me!
                rspierenburg
                Does anyone else notice that DRSpawner is using massive amounts of CPU power? I have it installed on two dual-core computers and its taking up 50% of the CPU resources on each. Just wondering if this is by design or is it a bug.
                  Yes, it's exactly what it should be doing - making use of your CPU to render.
                    rspierenburg
                    But that is without a render being started. I figured it would run idle until Vray calls upon it to start rendering. I figured I could leave it running on the slave computers but it seems like a lot of cpu strain for no reason. 😛
                    Rob
                      That ... is not normal... I have not seen that behaviour. I'd recommend you contact ASGVis Support.
                        Ugh.. I mean ChaosGroup USA - which is their new name. I can't get used to the change of name. 😒
                        • eidam655E
                          eidam655
                          i have EXACTLY this issue.
                          i even posted about it on the old ASGVis forum, before it got changed to chaosgroup...
                          (this is mine, but i can't find the asgvis forum link anymore (surprisingly))
                          if anyone had any idea, about what's going on, i (we) would be glad.
                          rspierenburg, what OS and CPU do you have? i have the same issue with a 32bit Vista with Intel C2D SL9400 and 64bit Win7 with Intel C2D E8400. or is it maybe with the installation? (1.49.01)
                          I'm using SketchUp 2017, V-Ray 3.4
                            j40
                            Rodrigo, Thank you ! for that great tutorial. I've cut the render time in half 😍
                            Top3D Studio
                            • rodrigonotorR
                              rodrigonotor
                              Your welcome, How many computers are you connecting?
                                j40
                                I connected with a LAN cable a notebook (4 cores) to my MacBook Pro (2 cores).
                                I don't know if it should be like that, but the second pc kicks in only in the rendering phase, meaning that in the LC calculating phase it's only my main pc working.
                                Oh, and I did have some problem with the textured geometry, that came out rendered as solid color. It took me a while to figure out that all it takes is to check the "Asset Collection" box. Maybe you could add that to the tutorial.
                                btw is it better to use LAN connection rather wifi?
                                Top3D Studio
                                • rodrigonotorR
                                  rodrigonotor
                                  Added "asset collection" settings to the tutorial.
                                  That depends on your wireless connection, if you have the same speed as your wired connection is the same thing. If not, the wired connection, most of the times is much faster than the WI-FI connection.
                                  Regards
                                    LAN is better than WLAN. Even if you have a WLAN with good speed, it's less reliable - random drop in connectivity etc.
                                      j40
                                      I thought so... for example the LAN Cable that I'm using is CAT5e 1000 Mbps. I don't think that Wifi can beat that... (?)
                                      BTW did someone tried to render IES lights with DR Spawner ?
                                      Top3D Studio
                                        It's not even about speed - it's about reliability. Just a minor drop in connectivity which you might not notice while browsing can cause havoc for your render.
                                          akaaka
                                          I'm trying to run a DR render on two mac. Unfortunately, during the rendering, it is used only computer's master processor. Below is the content of the window (10.0.1.19 is the address of the customer):
                                          Last login: Thu Nov 15 18:06:30 on ttys000
                                          MacBook-Pro:~ MD$ /Applications/ASGVIS/DRSpawner/XMLDRSpawner ; exit;
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:47: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                                          self.message = messages[errorCode] % msgargs
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:47: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:48: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                                          Exception.init(self, self.message, args)
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:48: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                                          e.message),
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                                          e.message),
                                          /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:584: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                                          FtWarning)
                                          FtWarning: Catalog resource (file:///usr/local/share/4Suite/default.cat)
                                          disabled: Error retrieving resource 'file:///usr/local/share/4Suite/default.cat
                                          (/usr/local/share/4Suite/default.cat)': [Errno 2] No such file or directory:
                                          '/usr/local/share/4Suite/default.cat'
                                          Successfully initialized spawner. Waiting for jobs...
                                          Starting DR session from 10.0.1.19
                                          Receiving DR scene from 10.0.1.19
                                          Error receiving DR scene (0), closing DR session
                                          • rodrigonotorR
                                            rodrigonotor
                                            Very good point. 👍
                                            • 1 / 3
