    [Request]Reset Interface or Turn all Plugins on/off
    11 Posts 8 Posters 1.1k Views 8 Watching
      matt.gordon320
      Hey Guys,
      I was curious if anybody has come across any scripts or plugins that might be able to accomplish this function: Turning all plugins on or off, and resetting the SU interface back to the default (after install). The reason I ask is because I do a lot of training/teaching, and I'd like to be able to switch back and forth between having my scripts loaded (for when I'm working or teaching an advanced user) and unloaded (for training someone who needs to learn the basics before jumping into plugins). It doesn't need to be dynamic or anything, just be able to switch somehow. I've searched around but can't seem to find anything. Has anybody heard of anything remotely like this?
      I'm planning on writing my own script for it eventually, but since I'm new to ruby code, that might take a while πŸ˜„
      Matt
      • Rich O BrienR Online
        I edited your post to replace [Plugin] with [Request] as the plugin tag is used where there are actual plugins to download.
          Jim
          Hi Matt,
          It may be possible, but may require Windows Registry hacking.
          Also, any Toolbars will not remember their previous locations after being re-enabled. It will be as if you just installed them all over again. If you only have a small number of plugins, that may be acceptable.
            mirale999
            I think you're finding this plugin:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=30078
            like Jim says, if you don't have so many plugins to switch on and off, it's useful~ πŸ˜„
            paranoia is a higher form of awareness...
              driven
              There is a Terminal Command for Mac's mentioned in the Lion thread by Tricia [google team]
              you type it in Terminal, then launch SU and you have NO plugins.
              don't type it in and you have ALL your plugins.
              An apple Script could do it for you...
              john
              • mitcorbM Offline
                mitcorb
                Hmmm Very interesting. An enhancement for Macs but none for Windows? Usually the other way around.
                • jeff hammondJ Offline
                  jeff hammond
                  why do you guys always have to be so difficult?
                  http://support.google.com/sketchup/bin/answer.py?answer=1700320
                  via:
                  http://support.google.com/sketchup/bin/static.py?hl=en&page=release_notes.cs
                  [ πŸ˜† ]
                  dotdotdot
                    driven
                    [ :lol: ]
                    That is for Maintenance release2 that's only been out for 1 or 2 days....
                    the terminal command works on other versions and doesn't require you to open SU/open RC/write/close/re-open SU for ON and then the same for OFF.
                    john
                      jeff hammond
                      [ πŸ˜† ]
                      or 1 or 2 hours even πŸ˜„
                      i'm just being silly.. sorry.
                      dotdotdot
                        driven
                        I found it amusing when I went to your links and saw what it was... keep it up john
                        • dukejazzD Offline
                          dukejazz
                          Please read:
                          5 tips about running more than one sketchup
                          http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                          Tip 1,5 & 2 may help
                          Load scripts with ruby toolbar or autoload
                          When you want to clear out loaded plugins script by starting another sketchup,
                          select all, copy and paste in place to newly loaded sketchup then exit out the old
                          tip 1)
                          You can run more than one sketchup programs at the same time.
                          Just hit your shortcut key twice and find out.
