    [Request]Reset Interface or Turn all Plugins on/off
    11 Posts 8 Posters 1.2k Views 8 Watching
      I edited your post to replace [Plugin] with [Request] as the plugin tag is used where there are actual plugins to download.
        Jim
        Hi Matt,
        It may be possible, but may require Windows Registry hacking.
        Also, any Toolbars will not remember their previous locations after being re-enabled. It will be as if you just installed them all over again. If you only have a small number of plugins, that may be acceptable.
          mirale999
          I think you're finding this plugin:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=30078
          like Jim says, if you don't have so many plugins to switch on and off, it's useful~ πŸ˜„
          paranoia is a higher form of awareness...
            driven
            There is a Terminal Command for Mac's mentioned in the Lion thread by Tricia [google team]
            you type it in Terminal, then launch SU and you have NO plugins.
            don't type it in and you have ALL your plugins.
            An apple Script could do it for you...
            • mitcorbM
              mitcorb
              Hmmm Very interesting. An enhancement for Macs but none for Windows? Usually the other way around.
              • jeff hammondJ
                why do you guys always have to be so difficult?
                Error 404 (Not Found)!!1
                (support.google.com)
                via:
                http://support.google.com/sketchup/bin/static.py?hl=en&page=release_notes.cs
                [ πŸ˜† ]
                  driven
                  [ :lol: ]
                  That is for Maintenance release2 that's only been out for 1 or 2 days....
                  the terminal command works on other versions and doesn't require you to open SU/open RC/write/close/re-open SU for ON and then the same for OFF.
                  • jeff hammondJ
                    [ πŸ˜† ]
                    or 1 or 2 hours even πŸ˜„
                    i'm just being silly.. sorry.
                      driven
                      I found it amusing when I went to your links and saw what it was... keep it up john
                      • dukejazzD
                        dukejazz
                        Please read:
                        5 tips about running more than one sketchup
                        http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                        Tip 1,5 & 2 may help
                        Load scripts with ruby toolbar or autoload
                        When you want to clear out loaded plugins script by starting another sketchup,
                        select all, copy and paste in place to newly loaded sketchup then exit out the old
                        tip 1)
                        You can run more than one sketchup programs at the same time.
                        Just hit your shortcut key twice and find out.
