    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 270.2k Views 41 Watching
    • jolranJ Offline
      jolran
      Not noow Kato!! πŸ‘Š πŸ˜„
      I don't understand Sergey. Do you want line weight? That is only possible
      through styles in Sketchup. But it's a global feature. I am afraid I can't do anything about that. Maybe if thin rectangles are grouped with materials
      like TIG,s dashed lines. But that is further on in developement.
      Look at my last minitut for an example how you can use differnt styles, with edge profiles for ex.
      Thanks for input Sergey! MUST CODE ON!! πŸ‘
      And yes TIG. I'm trying! πŸŽ‰
      • jolranJ Offline
        jolran
        This code gives me a face with holes. If I stop after this code.
        But cannot Hatch faces with holes in full script.
        Get an error πŸ˜•
        Normal (square faces) works fine in full script with the changed code, strange enough.
        gp.layer=hatch_layer    # group to Hatching layer
              gp.name=name
              gents=gp.entities
              faces2go=[]
              face.loops.each{|loop|gents.add_face(loop.vertices)}
              gents.each{|face|
              next if face.class!=Sketchup;;Face
              face.edges.each{|e|
              if not e.faces[1]
              break
              faces2go << face
         gents.erase_entities(faces2go)                #erase the faces in the holes
          Why not?
          How are you hatching?
          Stop at each stage with a temporary 'return nil' and see what you get or error messages etc... πŸ˜•
            linea
            Tig this is brilliant, wanted this for so long.
              sergey2402
              Whether not too much I want? 😳
              • K Offline
                kyyu
                jolran, a few suggests for you to consider.
                1. Seperate out the code that draws the line pattern, into it's own method. That will make your main program simpler to understand. It will look more like an outline. Check out my later example code snippet. I just premade the line pattern, by hand, which would represent simply calling a method to make it. Also, you can reuse the draw_lines method, say if you want to draw a 2nd set in the criss cross direction.
                2. Might want to consider a rethink. The program will become more complicated, if you just keep adding stuff on top of exsiting. Here's a possible new way, shown below. And the way I test stuff quickly, is to use the "Ruby Web Console" plugin by Jim Foltz. I often check parts of my program, like this, as snippets of code; before adding it to the plugin. You simply undo <ctrl+z>, change the line(s) of code and execute the code again, by hitting the "eval button".
                #This snippet puts the face,lines & hatch into 3 seperate groups.  Face is simply grouped, not copied.
                #The "lines" group is premade and named "lines", so the script can find it.
                #You need to select the face, before running script
                #No need to delete seperate edges, just delete the lines group when done.
                model = Sketchup.active_model
                ent = model.entities
                sel = model.selection
                f = sel[0]
                face = ent.add_group(f)
                lines = (ent.to_a.select {|e| e.is_a?(Sketchup;;Group) and e.name=="lines"})[0]
                puts lines
                hatch = ent.add_group
                hent=hatch.entities; lent=lines.entities; fent=face.entities
                htr=hatch.transformation; ltr=lines.transformation; ftr=face.transformation
                fent.intersect_with(true, ftr, hent, htr, false, lines)
                lines.erase!
                face.explode
                Snippet of code and model set up to run
                ![After pressing "eval" button](/uploads/imported_attachments/Hdko_test_hatch_rwc_after.png "After pressing "eval" button")
                test_hatch_RubyWebConsole.skp
                  Jim
                  This is very useful, jolran. Thanks for making it happen.
                  • K Offline
                    kaas
                    wonderful!! This kind of plugin (hopefully someday with some extra hatch options) is really what I was missing in SU.
                    Many thanks to those involved!
                    • jolranJ Offline
                      jolran
                      Sergey, thanks for your suggestions πŸ‘ I will probably go for something like the picture, first time around.
                      Unless I'm wrong you have to use webdialog for checkboxes, and I'll put that on hold for now.
                      More important issues to deal with first.
                      Hi Kyyu. Many thanks for your input and experimenting. Really appreciate it πŸ‘
                      I got a strong impression from reading this forum, that making groupes from selection is a bad choice? πŸ˜•
                      Thats why I neglected my original idea and went for TIG's "face.clone iterating stuff". Don't you get splats doing it like that? Have you tried this inside a group? I got constant splats doing almost exactly as you did.
                      However grouping the edges before doing an intersect_with might be a good idea. That might actually be an easier method than iteration the edges for erasing? Depends on how "splat-prone" the method is.
                      About separating to 3 groups. Don't know if that is necessary? Doesent it suffice to add the hatches to a new layer? (Which is already implemented in my current code). This grouping In my opinion does no good for the workflow. Need more feedback about that, please πŸ˜„
                      Yeah, I know code's a bit messy, but doing a second hatching that is probably a must anyway.
                      I'm using AS ruby code editor. It's the same as Jim's no?
                      Thank you Jim and Kaas! And TIG's been helping me a LOT, that goes without saying.
                      • jolranJ Offline
                        jolran
                        YES!!!! Faces with holes are hatching now. Will update tomorrow, hopefully.
                        Stupid newbie-mistake. I did not create "@face" object. So for ex bb=face.bounds
                        did not have anything to refer to since face was in Faces2go's scope. At least that is what I think happend. πŸ˜„
                        Will test more before I celebrate too much...
                        Sorry TIG, I missed your post from yesterday. I wasent using return nil. I used =begin and =end. That works equally good?
                        • jolranJ Offline
                          jolran
                          Testing.
                          • Bob JamesB Offline
                            Bob James
                            Looking Good πŸ‘
                            • K Offline
                              kyyu
                              Sorry, disregard, was trying to edit the previous post.
                                sergey2402
                                So when will come tomorrow? I am looking forward!
                                I am sure - in the new version of SketchUp this plugin should become a standard feature.
                                • K Offline
                                  kyyu
                                  jolran, looks like you got it working well. πŸ‘ So no need to change anything. I will answer the questions, anyways.
                                  Yes, it's to be avoided. But you can do it, under certain circumstances. Grouping loose geometry is ok, especially a single edge or face. In my example, I grouped a face at the very beginning. And it do it, just once. I've written plugins, like this, before. You can't do it what an entitiy, already inside a group. I'm assuming it has to be in the current active_entities.
                                  If, I am just testing a quick snippet of code, I certainly will just group the face instead of writing a bunch of lines to clone it.
                                  You only need to consider doing all this, if you didn't make the entitiy. If you want your lines in a group, then you would make an empty group 1st, and then create the lines directly in the group (gents.add_line instead of ents.add_line).
                                  It all depends on how you are doing stuff. My thoughts on 3 groups is as follows: Group1 is your cloned face group. If you decide to group your line pattern, then that's group2. When you use intersec_with, you can choose where the new lines go. You can't put them in group1 or group2. They would merge and you have to clean them up. So you put them in group3. Then you only need to delete group1 & group2. No need to find and delete any edges. That's what my example does. Except, I just explode group1, becasue I don't make a clone.
                                  Should be the same. Just suggesting an editor that can execute the code, if you aren't using one. I use Notepad++ for that and reload using Jim's Ruby Toolbar. But Jim's Ruby Web Console does the undo automatically. And very easy to test small bits of code. I still use his older version.
                                  -Kwok
                                    sergey2402
                                    Looking to the future, I regret to foresee, this plugin will be not freeware.
                                    • Rich O BrienR Online
                                      Do you have a crystal ball or some sixth sense? Will I be able to cut the grass tomorrow or will it rain?
                                        sergey2402
                                        The really good thing can not be free. It understandable without a crystal ball and without sixth sense. πŸ˜‰
                                        Good question, but a great pity to spend my magical powers to answer it. 😎
                                        • jolranJ Offline
                                          jolran
                                          Ver 1.3 added!
                                          Hole "issue" should work. At least it does for me..
                                          Note. Crosshatching does NOT work yet. Only menu items has been added. Layer Hatching now gets made with hatching in it.
                                          What say you about choice of keeping Face and being able to add material?
                                          This version needs to be tested. Have not recieved feedback from TIG about this update, and that makes me nervous πŸ˜„
                                          • jolranJ Offline
                                            jolran
                                            Kyyu! Thank you so much for your detailed explanation. Now I understand better. Much apreciated.
                                            I think your intersect method is worth experimenting with for upcoming features. And or what features is possible.
                                            No one in here needs to worry this will become a comersial plugin.
                                            Yes, of course I need to make money. But I have gotten so much help from TIG and Kyyu, Jim and others, so going comers. would be HIGHLY unethical! If even legal? This is a great learning experience for me, and I will try too remain humble and listen to
                                            advice and suggestions being made.
                                            Hatches, yes. So this work might be for nothing πŸ˜„ Although, it is possible only Layout will be the program that get hatches.
                                            • 17
                                            • 18
                                            • 3 / 18
