    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 298.2k Views 41 Watching
      all_loops=face.loops i.e. its is an array of all loops including the outer one
      outer_loop = face.outer_loop inner_loops = all_loops - [outer_loop]
      Although some of this is of academic interest as we only need all_loops...
      As I said before [in a PM]... you simply iterate through all loops and add a face for each loop using its vertices.
      all_loops.each{|loop|gents.add_face(loop.vertices)}
      You have the main face drawn... but with its holes filled in with other faces.
      We can erase these by testing to see if each face in gents has an edge with only one face [i.e. it's NOT in a hole], if not then we'll erase it...
      faces2go=[]
      gents.each{|face|
        next if face.class!=Sketchup;;Face
        face.edges.each{|e|
          if not e.faces[1]
            break
          faces2go << face
      gents.erase_entities(faces2go)
      [this code is untested and might have typos !]
      Now you should have a perfect clone of the face inside the group with any holes reproduced too.
      Do your intersecting of the hatch lines etc just as before and then when you erase 'faceless edges' the ones now crossing these 'holes' will be erased too πŸ˜„
      • jolranJ Offline
        jolran
        Great info! Will work on that.
        Do you mean {|loop|gents.add_face
        or {|loop|ents.add_face ?
        Thank you TIG. Got me some homework πŸ˜„
          The 'gents' refers to the group.entities where we are replicating the face ?
          • jolranJ Offline
            jolran
            Yes that make sence. I had already put a similar code from your pm in my editor where I had used ents.
            That was wrong then from my part. Makes thing clearer. Thanks! πŸ˜„
            • jolranJ Offline
              jolran
              Strange. Should work, but no innerface is created.
              Hatch gets created over whole face. I tried different combinations with
              these new lines added, but get errors then..
              gp=ents.add_group()
                    gp.name=name
                    gents=gp.entities
                    face=gents.add_face(face.outer_loop.vertices) # adds a faceclone from outer vertices loop
                    faces2go=[]  # was faces2gp? Typo? array for innerloups faces
                    face.loops.each{|loop|gents.add_face(loop.vertices)}   # creates inner loop
                    gents.each{|face|
                    face.edges.each{|e|
                    if not e.faces[1]
                    break
                  faces2go << face
                    gents.erase_entities(faces2go)                #erase the faces in the holes
                Try first adding the faces for the 'inner_loops' - each using loop.vertices in turn [i.e. face.loops-[face.outer_loop]], then add the face from face.outer_loop.vertices...
                This might work... To see what you are getting stop the code temporarily before the inner faces are erased and before any hatching is done - add a line 'return nil' in the code so that it stops... You should get the faces reproduced in the group. Then try with the inner face erase bit to see if they go [sans hatching...] πŸ˜•
                  sergey2402
                  Perhaps the thickness of the hatch lines should not be equal to the thickness of the edges? Like dimension lines.
                  • jolranJ Offline
                    jolran
                    Not noow Kato!! πŸ‘Š πŸ˜„
                    I don't understand Sergey. Do you want line weight? That is only possible
                    through styles in Sketchup. But it's a global feature. I am afraid I can't do anything about that. Maybe if thin rectangles are grouped with materials
                    like TIG,s dashed lines. But that is further on in developement.
                    Look at my last minitut for an example how you can use differnt styles, with edge profiles for ex.
                    Thanks for input Sergey! MUST CODE ON!! πŸ‘
                    And yes TIG. I'm trying! πŸŽ‰
                    • jolranJ Offline
                      jolran
                      This code gives me a face with holes. If I stop after this code.
                      But cannot Hatch faces with holes in full script.
                      Get an error πŸ˜•
                      Normal (square faces) works fine in full script with the changed code, strange enough.
                      gp.layer=hatch_layer    # group to Hatching layer
                            gp.name=name
                            gents=gp.entities
                            faces2go=[]
                            gents.each{|face|
                            face.edges.each{|e|
                            if not e.faces[1]
                            break
                            faces2go << face
                        Why not?
                        How are you hatching?
                        Stop at each stage with a temporary 'return nil' and see what you get or error messages etc... πŸ˜•
                          linea
                          Tig this is brilliant, wanted this for so long.
                            sergey2402
                            Whether not too much I want? 😳
                              kyyu
                              jolran, a few suggests for you to consider.
                              1. Seperate out the code that draws the line pattern, into it's own method. That will make your main program simpler to understand. It will look more like an outline. Check out my later example code snippet. I just premade the line pattern, by hand, which would represent simply calling a method to make it. Also, you can reuse the draw_lines method, say if you want to draw a 2nd set in the criss cross direction.
                              2. Might want to consider a rethink. The program will become more complicated, if you just keep adding stuff on top of exsiting. Here's a possible new way, shown below. And the way I test stuff quickly, is to use the "Ruby Web Console" plugin by Jim Foltz. I often check parts of my program, like this, as snippets of code; before adding it to the plugin. You simply undo <ctrl+z>, change the line(s) of code and execute the code again, by hitting the "eval button".
                              #This snippet puts the face,lines & hatch into 3 seperate groups.  Face is simply grouped, not copied.
                              #The "lines" group is premade and named "lines", so the script can find it.
                              #You need to select the face, before running script
                              #No need to delete seperate edges, just delete the lines group when done.
                              model = Sketchup.active_model
                              ent = model.entities
                              sel = model.selection
                              f = sel[0]
                              face = ent.add_group(f)
                              lines = (ent.to_a.select {|e| e.is_a?(Sketchup;;Group) and e.name=="lines"})[0]
                              puts lines
                              hatch = ent.add_group
                              hent=hatch.entities; lent=lines.entities; fent=face.entities
                              htr=hatch.transformation; ltr=lines.transformation; ftr=face.transformation
                              fent.intersect_with(true, ftr, hent, htr, false, lines)
                              lines.erase!
                              face.explode
                              Snippet of code and model set up to run
                              ![After pressing "eval" button](/uploads/imported_attachments/Hdko_test_hatch_rwc_after.png "After pressing "eval" button")
                              test_hatch_RubyWebConsole.skp
                                Jim
                                This is very useful, jolran. Thanks for making it happen.
                                  kaas
                                  wonderful!! This kind of plugin (hopefully someday with some extra hatch options) is really what I was missing in SU.
                                  Many thanks to those involved!
                                  • jolranJ Offline
                                    jolran
                                    Sergey, thanks for your suggestions πŸ‘ I will probably go for something like the picture, first time around.
                                    Unless I'm wrong you have to use webdialog for checkboxes, and I'll put that on hold for now.
                                    More important issues to deal with first.
                                    Hi Kyyu. Many thanks for your input and experimenting. Really appreciate it πŸ‘
                                    I got a strong impression from reading this forum, that making groupes from selection is a bad choice? πŸ˜•
                                    Thats why I neglected my original idea and went for TIG's "face.clone iterating stuff". Don't you get splats doing it like that? Have you tried this inside a group? I got constant splats doing almost exactly as you did.
                                    However grouping the edges before doing an intersect_with might be a good idea. That might actually be an easier method than iteration the edges for erasing? Depends on how "splat-prone" the method is.
                                    About separating to 3 groups. Don't know if that is necessary? Doesent it suffice to add the hatches to a new layer? (Which is already implemented in my current code). This grouping In my opinion does no good for the workflow. Need more feedback about that, please πŸ˜„
                                    Yeah, I know code's a bit messy, but doing a second hatching that is probably a must anyway.
                                    I'm using AS ruby code editor. It's the same as Jim's no?
                                    Thank you Jim and Kaas! And TIG's been helping me a LOT, that goes without saying.
                                    • jolranJ Offline
                                      jolran
                                      YES!!!! Faces with holes are hatching now. Will update tomorrow, hopefully.
                                      Stupid newbie-mistake. I did not create "@face" object. So for ex bb=face.bounds
                                      did not have anything to refer to since face was in Faces2go's scope. At least that is what I think happend. πŸ˜„
                                      Will test more before I celebrate too much...
                                      Sorry TIG, I missed your post from yesterday. I wasent using return nil. I used =begin and =end. That works equally good?
                                      • jolranJ Offline
                                        jolran
                                        Testing.
                                        • Bob JamesB Offline
                                          Bob James
                                          Looking Good πŸ‘
                                            kyyu
                                            Sorry, disregard, was trying to edit the previous post.
                                            • 17
                                            • 18
                                            • 3 / 18
