    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 317.9k Views 41 Watching
    • jolranJ
      jolran
      Great info! Will work on that.
      Do you mean {|loop|gents.add_face
      or {|loop|ents.add_face ?
      Thank you TIG. Got me some homework πŸ˜„
        The 'gents' refers to the group.entities where we are replicating the face ?
        • jolranJ
          jolran
          Yes that make sence. I had already put a similar code from your pm in my editor where I had used ents.
          That was wrong then from my part. Makes thing clearer. Thanks! πŸ˜„
          • jolranJ
            jolran
            Strange. Should work, but no innerface is created.
            Hatch gets created over whole face. I tried different combinations with
            these new lines added, but get errors then..
            gp=ents.add_group()
                  gp.name=name
                  gents=gp.entities
                  face=gents.add_face(face.outer_loop.vertices) # adds a faceclone from outer vertices loop
                  faces2go=[]  # was faces2gp? Typo? array for innerloups faces
                  face.loops.each{|loop|gents.add_face(loop.vertices)}   # creates inner loop
                  gents.each{|face|
                  next if face.class!=Sketchup;;Face
                  face.edges.each{|e|
                  if not e.faces[1]
                  break
                faces2go << face
                  gents.erase_entities(faces2go)                #erase the faces in the holes
              Try first adding the faces for the 'inner_loops' - each using loop.vertices in turn [i.e. face.loops-[face.outer_loop]], then add the face from face.outer_loop.vertices...
              This might work... To see what you are getting stop the code temporarily before the inner faces are erased and before any hatching is done - add a line 'return nil' in the code so that it stops... You should get the faces reproduced in the group. Then try with the inner face erase bit to see if they go [sans hatching...] πŸ˜•
                sergey2402
                Perhaps the thickness of the hatch lines should not be equal to the thickness of the edges? Like dimension lines.
                • jolranJ
                  jolran
                  Not noow Kato!! πŸ‘Š πŸ˜„
                  I don't understand Sergey. Do you want line weight? That is only possible
                  through styles in Sketchup. But it's a global feature. I am afraid I can't do anything about that. Maybe if thin rectangles are grouped with materials
                  like TIG,s dashed lines. But that is further on in developement.
                  Look at my last minitut for an example how you can use differnt styles, with edge profiles for ex.
                  Thanks for input Sergey! MUST CODE ON!! πŸ‘
                  And yes TIG. I'm trying! πŸŽ‰
                  • jolranJ
                    jolran
                    This code gives me a face with holes. If I stop after this code.
                    But cannot Hatch faces with holes in full script.
                    Get an error πŸ˜•
                    Normal (square faces) works fine in full script with the changed code, strange enough.
                    gp.layer=hatch_layer    # group to Hatching layer
                          gp.name=name
                          gents=gp.entities
                          faces2go=[]
                          gents.each{|face|
                          face.edges.each{|e|
                          if not e.faces[1]
                          break
                          faces2go << face
                      Why not?
                      How are you hatching?
                      Stop at each stage with a temporary 'return nil' and see what you get or error messages etc... πŸ˜•
                      • L
                        linea
                        Tig this is brilliant, wanted this for so long.
                          sergey2402
                          Whether not too much I want? 😳
                          • K
                            kyyu
                            jolran, a few suggests for you to consider.
                            1. Seperate out the code that draws the line pattern, into it's own method. That will make your main program simpler to understand. It will look more like an outline. Check out my later example code snippet. I just premade the line pattern, by hand, which would represent simply calling a method to make it. Also, you can reuse the draw_lines method, say if you want to draw a 2nd set in the criss cross direction.
                            2. Might want to consider a rethink. The program will become more complicated, if you just keep adding stuff on top of exsiting. Here's a possible new way, shown below. And the way I test stuff quickly, is to use the "Ruby Web Console" plugin by Jim Foltz. I often check parts of my program, like this, as snippets of code; before adding it to the plugin. You simply undo <ctrl+z>, change the line(s) of code and execute the code again, by hitting the "eval button".
                            #This snippet puts the face,lines & hatch into 3 seperate groups.  Face is simply grouped, not copied.
                            #The "lines" group is premade and named "lines", so the script can find it.
                            #You need to select the face, before running script
                            #No need to delete seperate edges, just delete the lines group when done.
                            model = Sketchup.active_model
                            ent = model.entities
                            sel = model.selection
                            f = sel[0]
                            face = ent.add_group(f)
                            lines = (ent.to_a.select {|e| e.is_a?(Sketchup;;Group) and e.name=="lines"})[0]
                            puts lines
                            hatch = ent.add_group
                            hent=hatch.entities; lent=lines.entities; fent=face.entities
                            htr=hatch.transformation; ltr=lines.transformation; ftr=face.transformation
                            fent.intersect_with(true, ftr, hent, htr, false, lines)
                            lines.erase!
                            face.explode
                            Snippet of code and model set up to run
                            ![After pressing "eval" button](/uploads/imported_attachments/Hdko_test_hatch_rwc_after.png "After pressing "eval" button")
                            test_hatch_RubyWebConsole.skp
                              Jim
                              This is very useful, jolran. Thanks for making it happen.
                              • K
                                kaas
                                wonderful!! This kind of plugin (hopefully someday with some extra hatch options) is really what I was missing in SU.
                                Many thanks to those involved!
                                • jolranJ
                                  jolran
                                  Sergey, thanks for your suggestions πŸ‘ I will probably go for something like the picture, first time around.
                                  Unless I'm wrong you have to use webdialog for checkboxes, and I'll put that on hold for now.
                                  More important issues to deal with first.
                                  Hi Kyyu. Many thanks for your input and experimenting. Really appreciate it πŸ‘
                                  I got a strong impression from reading this forum, that making groupes from selection is a bad choice? πŸ˜•
                                  Thats why I neglected my original idea and went for TIG's "face.clone iterating stuff". Don't you get splats doing it like that? Have you tried this inside a group? I got constant splats doing almost exactly as you did.
                                  However grouping the edges before doing an intersect_with might be a good idea. That might actually be an easier method than iteration the edges for erasing? Depends on how "splat-prone" the method is.
                                  About separating to 3 groups. Don't know if that is necessary? Doesent it suffice to add the hatches to a new layer? (Which is already implemented in my current code). This grouping In my opinion does no good for the workflow. Need more feedback about that, please πŸ˜„
                                  Yeah, I know code's a bit messy, but doing a second hatching that is probably a must anyway.
                                  I'm using AS ruby code editor. It's the same as Jim's no?
                                  Thank you Jim and Kaas! And TIG's been helping me a LOT, that goes without saying.
                                  • jolranJ
                                    jolran
                                    YES!!!! Faces with holes are hatching now. Will update tomorrow, hopefully.
                                    Stupid newbie-mistake. I did not create "@face" object. So for ex bb=face.bounds
                                    did not have anything to refer to since face was in Faces2go's scope. At least that is what I think happend. πŸ˜„
                                    Will test more before I celebrate too much...
                                    Sorry TIG, I missed your post from yesterday. I wasent using return nil. I used =begin and =end. That works equally good?
                                    • jolranJ
                                      jolran
                                      Testing.
                                      • Bob JamesB
                                        Bob James
                                        Looking Good πŸ‘
                                        • K
                                          kyyu
                                          Sorry, disregard, was trying to edit the previous post.
                                            sergey2402
                                            So when will come tomorrow? I am looking forward!
                                            I am sure - in the new version of SketchUp this plugin should become a standard feature.
                                            • 17
                                            • 18
                                            • 3 / 18
