    Drawing a bolt
    5 Posts 5 Posters 689 Views 5 Watching
    • G Offline
      gemonds
      Hello
      I try to draw a threaded bolt. I have the plug-in clf_shape_bender.rb and progressbar.rb installed. Simultaneously with the film on youtube http://www.youtube.com/watch?v=MKrWDNDd62c I draw the bolt. When I use clf_shape_bender I get a wireframe drawn on the spiral. Then I press enter. I Get three spirals on the corners of the triangle. Only a small part has three outside surfaces. Can someone help me with any tips.
      Kind regards
      Gerard
        Without more detail I suspect you might be suffering from the 'small-faces-issue'.
        Sketchup/OpenGL can't manage to make very small facets [<~1mm].
        If you scale up what you are making [inside a group] x10 or x100 you might find the faces form.
        Afterwards you can scale back down x0.1 or x0.01 as small faces can exist, it's just making them that fails...
          Very cool tutorial video! 😎
          • kenK Offline
            ken
            Note, I use a lot of bolts in my design. However I do not draw the threads as this is just a lot of graphic weight for nothing.
            Note, Bolt Builder V3, by Howard Leslie is a great tool for making bolts.
            Ken
            • jeff hammondJ Offline
              jeff hammond
              re: that video.
              be wary of that helix drawing technique shown at the beginning.. the half-circle_move_one_end_up then copy/rotating deal isn't actually drawing a helix..
              while it might look ok at a glance, don't rely on doing that if accuracy is ever of importance.
              dotdotdot
