    [Request] Name, Definition Name of Components
    16 Posts 2 Posters 1.2k Views 2 Watching
      Said I have a collection of various numerous components
      I wish rename all this collection of component selected like this
      First component
      Definition name = Dice1
      Name = Dice
      second component
      Definition name = Dice2
      Name = Dice
      third component
      Definition name = Dice3
      Name = Dice
      etc...
      Thx by advance β˜€
        def renameInstances()
        model=Sketchup.active_model
        model.definitions.each{|defn|
          name=defn.name
          puts "Defn Name= "+name
          name.gsub!(/[0-9]+$/,'')
          name='Doh!' if name==''
          defn.instances.each{|inst|
            inst.name=name
            puts "Inst Name= "+name
        end#def
        πŸ€“
          Thx but this can works on the ruby console? 😳
          I believe some scriptor will use it πŸ˜‰
            Ok I play to the coder but sorry where I input the name "Dice"? 😳
            I save that in a rb file, for appear in a menu - works fine
            try some places for input "Dice"
            but seems I miss something πŸ˜’
              My quick example code works on all instances of all definitions...
              If you want to affect only a certain named collection of definitions then this version will work for you...
              You save it as renameInstances.rb in ../Plugins/ and run it by typing renameInstances 'Dice' in the Ruby Console - where 'Dice' [inside ' ' or " "] is the 'string' pattern we'll look for in the definitions' names. Note how 'Dice' matches that text anywhere in the name, but adding a leading '^' as in '^Dice' matches only if the string is at the very start, or with a trailing '$' as in 'Dice$' it matches the string only at the very end - AND combos inside '[]' as in '[Dd]ice' matches with both 'Dice' and 'dice', anywhere in the names etc; if you add no 'argument' then ALL are definitions/instances are processed.
              I've also removed groups/images from the processing, and I've added a one step undo...
              def renameInstances(str = '')
                  str=str.to_s ### makes sure!
                  model = Sketchup.active_model
                  model.start_operation('renameInstances')
                    next if defn.image? or defn.group?
                    dname = defn.name
                    if str != ''
                      next if dname.gsub(/#{str}/,'') == dname
                      ### NO match to 'str' so skip it...
                    end#if
                    puts "Defn Name = "+dname
                    iname = dname.gsub(/[0-9]+$/, '')
                    ### i.e. it strips ALL numerals OFF the end of 'name'
                    iname = 'Doh!' if iname == ''
                    ### i.e. it was ALL numerals and so it vanished !!
                      inst.name = iname
                      puts "Inst Name = "+iname
                  model.commit_operation
              end#def
                In V6
                I have 2 components no instancied
                with definition name: Component#1, Component#2 all without name
                Wishing
                definition name: Dice1, name: Dice
                definition name: Dice2, name: Dice
                I select the 2 component
                launched in ruby Console your last ruby script, type renameInstances 'Dice'
                result :
                True
                but nothing is changed for my 2 components selected 😳
                  In V6
                  I have 2 components
                  Wishing
                  launched in ruby Console your last ruby script : result
                  True
                  It doesn't work like that... AND you never asked for that, initially you said that you had a component named 'Dice1' and you wanted to name its instances as 'Dice' πŸ˜’ πŸ˜’ πŸ˜’
                  Where in my description did I say it works on renaming a selected component ???
                  You now say you want to rename 'Component#1' as 'Dice1' and rename its instances as 'Dice'.
                  That's completely different!!
                  First you need a renameDefinitions tool to change the name of 'Component#1' to be 'Dice1' and then use the current tool to rename 'Dice...' definitions' instances as 'Dice'.
                  Save this code into a file in Plugins called 'renameDefinitions.rb'.
                  Usage: in the Ruby Console type in
                  renameDefinitions 'Component#', 'Dice'
                  to rename all components containing that text, which are renamed with the new text 'Dice' - so
                  'Component#1' >>> 'Dice1'
                  'Component#2' >>> 'Dice2'
                  but 'Component' stays as 'Component'
                  If there is no second argument the matching text is simply removed from the name.
                  To match only the first two 'Component#' definitions use a pattern like
                  renameDefinitions 'Component#[12]$', 'Dice#1'
                  So only
                  'Component#1' >>> 'Dice#1'
                  'Component#2' >>> 'Dice#2'
                  but 'Component#3' stays as 'Component#3'
                  To fix the '#' in the replacement 'Dice#', run again as
                  renameDefinitions 'Dice#', 'Dice'
                  so all of the 'Dice#' names >>> 'Dice' names...
                  OR if bizzare is needed
                  renameDefinitions 'Dice#', 'AfghanistanBananistan' πŸ˜’
                  So
                  def renameDefinitions(str = '', txt = '')
                          str = str.to_s ### makes sure!
                          txt = txt.to_s
                          model.start_operation('renameDefinitions')
                            dname = defn.name
                            if str != ''
                            end#if
                            nname = dname.gsub(/#{str}/, txt)
                            ### i.e. it replaces str with txt
                            nname = 'Doh!' if nname == ''
                            ### i.e. it was an exact match and txt=''!!
                            defn.name = nname
                            puts "Defn Name; "+dname+" = "+nname
                  end#def
                  NOW use the renameInstances tool to change any instances of renamed definitions as a second step. πŸ€“
                    That what that: missunderstanding my first post πŸ˜‰
                    If you re read sequentially my first post I never said that i had component named Dice
                    I said "I wish" πŸ˜‰
                      First component
                      Name = Dice
                      IF you had said:
                      I wish to rename all selected components like this...
                      Definition name = 'Component#1'
                      New Definition name = 'Dice1'
                      New Instances name = 'Dice'
                      That's what you would have got!
                      Anyway, you now have something that will do it what you want - renaming the definitions by pattern matching and then a second tool renaming the matching definitions' instances by stripping off the numerical part of the defn name and using that...
                        Thx for your efforts β˜€
                        No possibility to enter a joker ?
                        because my selection of components can have any Definition names!
                        So make a general renaming in one pass
                          Of course all your components will have a name - even if it's 'Component#1' it's still a name ???
                          Therefore you'd use
                          which acts like a 'wildcard' and every component containing the text 'Component#' will have that replaced with 'Dice' ??????
                          So 'Component#1 >>> 'Dice1', 'Component#2 >>> 'Dice2' etc
                          As I then explained further you can constrain the renaming to a smaller set by using other pattern matching like [1238] to just process the first three and the eighth one
                          renameDefinitions 'Component#[1238]', 'Dice#1'
                          to rename them all first as as 'Dice#1', 'Dice#2' etc and then in a second step using
                          to rename them all as as 'Dice1', 'Dice2' etc...
                          This does NOT work on a highlighted 'selection' !!
                          You make your selection using a pattern matching string in the name!!!! πŸ€“
                            So there is no possibility to change 2 objects components Definition named
                            Ball
                            Poll
                            to these Definition named Dice1, Dice2 in one pass?
                              No...
                                Finally i have found a trick with another Console Script of your! πŸ‘
                                I explode all components selected and call your tricky thing who tranform any selections in Components! 😎
                                m=Sketchup.active_model;  ### tranform any selections in Components By TIG
                                m.start_operation("Faces>Compos");
                                n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
                                g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
                                m.commit_operation
                                So obtain a generic Components' name: FaceSet#1, FaceSet#2 etc...
                                Call your renameInstances many posts above
                                So obtain an only one name for all the Components: FaceSet#
                                So I can use it inside the Plug Random Replace Component
                                and even now no kneed to change it in Dice! πŸ˜’
                                ...but I must change my tutorial! πŸ’š
                                Thanks again for your lessons! πŸ‘
                                I have seen many things about renaming but see also that I am definitly not made for ruby scripting! πŸ˜’
                                  and...In fact that is some redundant with the use of the Dialog box Info for rename a group of components! 😳
                                  I had an headache for a so simple solution πŸ˜„
                                    My trick works only with components with no level of component inside πŸ˜’
                                    and for rename a same component with definition name "Ball" existing in different positions
                                    as new components with of course new definitions name Ball1, Ball2, Ball3 etc... ?
                                    I suppose they must be "Make Unic" then renamed
