    [Request] Name, Definition Name of Components
    16 Posts 2 Posters 1.4k Views 2 Watching
      def renameInstances()
      model=Sketchup.active_model
      model.definitions.each{|defn|
        name=defn.name
        puts "Defn Name= "+name
        name.gsub!(/[0-9]+$/,'')
        name='Doh!' if name==''
        defn.instances.each{|inst|
          inst.name=name
          puts "Inst Name= "+name
      end#def
      πŸ€“
        Thx but this can works on the ruby console? 😳
        I believe some scriptor will use it πŸ˜‰
          Ok I play to the coder but sorry where I input the name "Dice"? 😳
          I save that in a rb file, for appear in a menu - works fine
          try some places for input "Dice"
          but seems I miss something πŸ˜’
            My quick example code works on all instances of all definitions...
            If you want to affect only a certain named collection of definitions then this version will work for you...
            You save it as renameInstances.rb in ../Plugins/ and run it by typing renameInstances 'Dice' in the Ruby Console - where 'Dice' [inside ' ' or " "] is the 'string' pattern we'll look for in the definitions' names. Note how 'Dice' matches that text anywhere in the name, but adding a leading '^' as in '^Dice' matches only if the string is at the very start, or with a trailing '$' as in 'Dice$' it matches the string only at the very end - AND combos inside '[]' as in '[Dd]ice' matches with both 'Dice' and 'dice', anywhere in the names etc; if you add no 'argument' then ALL are definitions/instances are processed.
            I've also removed groups/images from the processing, and I've added a one step undo...
            def renameInstances(str = '')
                str=str.to_s ### makes sure!
                model = Sketchup.active_model
                model.start_operation('renameInstances')
                  next if defn.image? or defn.group?
                  dname = defn.name
                  if str != ''
                    next if dname.gsub(/#{str}/,'') == dname
                    ### NO match to 'str' so skip it...
                  end#if
                  puts "Defn Name = "+dname
                  iname = dname.gsub(/[0-9]+$/, '')
                  ### i.e. it strips ALL numerals OFF the end of 'name'
                  iname = 'Doh!' if iname == ''
                  ### i.e. it was ALL numerals and so it vanished !!
                    inst.name = iname
                    puts "Inst Name = "+iname
                model.commit_operation
            end#def
              In V6
              I have 2 components no instancied
              with definition name: Component#1, Component#2 all without name
              Wishing
              definition name: Dice1, name: Dice
              definition name: Dice2, name: Dice
              I select the 2 component
              launched in ruby Console your last ruby script, type renameInstances 'Dice'
              result :
              True
              but nothing is changed for my 2 components selected 😳
                In V6
                I have 2 components
                Wishing
                launched in ruby Console your last ruby script : result
                True
                It doesn't work like that... AND you never asked for that, initially you said that you had a component named 'Dice1' and you wanted to name its instances as 'Dice' πŸ˜’ πŸ˜’ πŸ˜’
                Where in my description did I say it works on renaming a selected component ???
                You now say you want to rename 'Component#1' as 'Dice1' and rename its instances as 'Dice'.
                That's completely different!!
                First you need a renameDefinitions tool to change the name of 'Component#1' to be 'Dice1' and then use the current tool to rename 'Dice...' definitions' instances as 'Dice'.
                Save this code into a file in Plugins called 'renameDefinitions.rb'.
                Usage: in the Ruby Console type in
                renameDefinitions 'Component#', 'Dice'
                to rename all components containing that text, which are renamed with the new text 'Dice' - so
                'Component#1' >>> 'Dice1'
                'Component#2' >>> 'Dice2'
                but 'Component' stays as 'Component'
                If there is no second argument the matching text is simply removed from the name.
                To match only the first two 'Component#' definitions use a pattern like
                renameDefinitions 'Component#[12]$', 'Dice#1'
                So only
                'Component#1' >>> 'Dice#1'
                'Component#2' >>> 'Dice#2'
                but 'Component#3' stays as 'Component#3'
                To fix the '#' in the replacement 'Dice#', run again as
                renameDefinitions 'Dice#', 'Dice'
                so all of the 'Dice#' names >>> 'Dice' names...
                OR if bizzare is needed
                renameDefinitions 'Dice#', 'AfghanistanBananistan' πŸ˜’
                So
                def renameDefinitions(str = '', txt = '')
                        str = str.to_s ### makes sure!
                        txt = txt.to_s
                        model.start_operation('renameDefinitions')
                          dname = defn.name
                          if str != ''
                          end#if
                          nname = dname.gsub(/#{str}/, txt)
                          ### i.e. it replaces str with txt
                          nname = 'Doh!' if nname == ''
                          ### i.e. it was an exact match and txt=''!!
                          defn.name = nname
                          puts "Defn Name; "+dname+" = "+nname
                end#def
                NOW use the renameInstances tool to change any instances of renamed definitions as a second step. πŸ€“
                  That what that: missunderstanding my first post πŸ˜‰
                  If you re read sequentially my first post I never said that i had component named Dice
                  I said "I wish" πŸ˜‰
                    I wish rename all this collection of component selected like this
                    First component
                    Definition name = Dice1
                    Name = Dice
                    IF you had said:
                    I wish to rename all selected components like this...
                    Definition name = 'Component#1'
                    New Definition name = 'Dice1'
                    New Instances name = 'Dice'
                    That's what you would have got!
                    Anyway, you now have something that will do it what you want - renaming the definitions by pattern matching and then a second tool renaming the matching definitions' instances by stripping off the numerical part of the defn name and using that...
                      Thx for your efforts β˜€
                      No possibility to enter a joker ?
                      because my selection of components can have any Definition names!
                      So make a general renaming in one pass
                        Of course all your components will have a name - even if it's 'Component#1' it's still a name ???
                        Therefore you'd use
                        which acts like a 'wildcard' and every component containing the text 'Component#' will have that replaced with 'Dice' ??????
                        So 'Component#1 >>> 'Dice1', 'Component#2 >>> 'Dice2' etc
                        As I then explained further you can constrain the renaming to a smaller set by using other pattern matching like [1238] to just process the first three and the eighth one
                        renameDefinitions 'Component#[1238]', 'Dice#1'
                        to rename them all first as as 'Dice#1', 'Dice#2' etc and then in a second step using
                        to rename them all as as 'Dice1', 'Dice2' etc...
                        This does NOT work on a highlighted 'selection' !!
                        You make your selection using a pattern matching string in the name!!!! πŸ€“
                          So there is no possibility to change 2 objects components Definition named
                          Ball
                          Poll
                          to these Definition named Dice1, Dice2 in one pass?
                            No...
                              Finally i have found a trick with another Console Script of your! πŸ‘
                              I explode all components selected and call your tricky thing who tranform any selections in Components! 😎
                              m=Sketchup.active_model;  ### tranform any selections in Components By TIG
                              m.start_operation("Faces>Compos");
                              n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
                              g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
                              m.commit_operation
                              So obtain a generic Components' name: FaceSet#1, FaceSet#2 etc...
                              Call your renameInstances many posts above
                              So obtain an only one name for all the Components: FaceSet#
                              So I can use it inside the Plug Random Replace Component
                              and even now no kneed to change it in Dice! πŸ˜’
                              ...but I must change my tutorial! πŸ’š
                              Thanks again for your lessons! πŸ‘
                              I have seen many things about renaming but see also that I am definitly not made for ruby scripting! πŸ˜’
                                and...In fact that is some redundant with the use of the Dialog box Info for rename a group of components! 😳
                                I had an headache for a so simple solution πŸ˜„
                                  My trick works only with components with no level of component inside πŸ˜’
                                  and for rename a same component with definition name "Ball" existing in different positions
                                  as new components with of course new definitions name Ball1, Ball2, Ball3 etc... ?
                                  I suppose they must be "Make Unic" then renamed
