    [Request] Name, Definition Name of Components
    16 Posts 2 Posters 1.2k Views 2 Watching
      My quick example code works on all instances of all definitions...
      If you want to affect only a certain named collection of definitions then this version will work for you...
      You save it as renameInstances.rb in ../Plugins/ and run it by typing renameInstances 'Dice' in the Ruby Console - where 'Dice' [inside ' ' or " "] is the 'string' pattern we'll look for in the definitions' names. Note how 'Dice' matches that text anywhere in the name, but adding a leading '^' as in '^Dice' matches only if the string is at the very start, or with a trailing '$' as in 'Dice$' it matches the string only at the very end - AND combos inside '[]' as in '[Dd]ice' matches with both 'Dice' and 'dice', anywhere in the names etc; if you add no 'argument' then ALL are definitions/instances are processed.
      I've also removed groups/images from the processing, and I've added a one step undo...
      def renameInstances(str = '')
          str=str.to_s ### makes sure!
          model = Sketchup.active_model
          model.start_operation('renameInstances')
          model.definitions.each{|defn|
            next if defn.image? or defn.group?
            dname = defn.name
            if str != ''
              next if dname.gsub(/#{str}/,'') == dname
              ### NO match to 'str' so skip it...
            end#if
            puts "Defn Name = "+dname
            iname = dname.gsub(/[0-9]+$/, '')
            ### i.e. it strips ALL numerals OFF the end of 'name'
            iname = 'Doh!' if iname == ''
            ### i.e. it was ALL numerals and so it vanished !!
            defn.instances.each{|inst|
              inst.name = iname
              puts "Inst Name = "+iname
          model.commit_operation
      end#def
        In V6
        I have 2 components no instancied
        with definition name: Component#1, Component#2 all without name
        Wishing
        definition name: Dice1, name: Dice
        definition name: Dice2, name: Dice
        I select the 2 component
        launched in ruby Console your last ruby script, type renameInstances 'Dice'
        result :
        True
        but nothing is changed for my 2 components selected 😳
          In V6
          I have 2 components
          Wishing
          launched in ruby Console your last ruby script : result
          True
          It doesn't work like that... AND you never asked for that, initially you said that you had a component named 'Dice1' and you wanted to name its instances as 'Dice' πŸ˜’ πŸ˜’ πŸ˜’
          Where in my description did I say it works on renaming a selected component ???
          You now say you want to rename 'Component#1' as 'Dice1' and rename its instances as 'Dice'.
          That's completely different!!
          First you need a renameDefinitions tool to change the name of 'Component#1' to be 'Dice1' and then use the current tool to rename 'Dice...' definitions' instances as 'Dice'.
          Save this code into a file in Plugins called 'renameDefinitions.rb'.
          Usage: in the Ruby Console type in
          renameDefinitions 'Component#', 'Dice'
          to rename all components containing that text, which are renamed with the new text 'Dice' - so
          'Component#1' >>> 'Dice1'
          'Component#2' >>> 'Dice2'
          but 'Component' stays as 'Component'
          If there is no second argument the matching text is simply removed from the name.
          To match only the first two 'Component#' definitions use a pattern like
          renameDefinitions 'Component#[12]$', 'Dice#1'
          So only
          'Component#1' >>> 'Dice#1'
          'Component#2' >>> 'Dice#2'
          but 'Component#3' stays as 'Component#3'
          To fix the '#' in the replacement 'Dice#', run again as
          renameDefinitions 'Dice#', 'Dice'
          so all of the 'Dice#' names >>> 'Dice' names...
          OR if bizzare is needed
          renameDefinitions 'Dice#', 'AfghanistanBananistan' πŸ˜’
          So
          def renameDefinitions(str = '', txt = '')
                  str = str.to_s ### makes sure!
                  txt = txt.to_s
                  model.start_operation('renameDefinitions')
                    dname = defn.name
                    if str != ''
                    end#if
                    nname = dname.gsub(/#{str}/, txt)
                    ### i.e. it replaces str with txt
                    nname = 'Doh!' if nname == ''
                    ### i.e. it was an exact match and txt=''!!
                    defn.name = nname
                    puts "Defn Name; "+dname+" = "+nname
          end#def
          NOW use the renameInstances tool to change any instances of renamed definitions as a second step. πŸ€“
            That what that: missunderstanding my first post πŸ˜‰
            If you re read sequentially my first post I never said that i had component named Dice
            I said "I wish" πŸ˜‰
              I wish rename all this collection of component selected like this
              First component
              Definition name = Dice1
              Name = Dice
              IF you had said:
              I wish to rename all selected components like this...
              Definition name = 'Component#1'
              New Definition name = 'Dice1'
              New Instances name = 'Dice'
              That's what you would have got!
              Anyway, you now have something that will do it what you want - renaming the definitions by pattern matching and then a second tool renaming the matching definitions' instances by stripping off the numerical part of the defn name and using that...
                Thx for your efforts β˜€
                No possibility to enter a joker ?
                because my selection of components can have any Definition names!
                So make a general renaming in one pass
                  Of course all your components will have a name - even if it's 'Component#1' it's still a name ???
                  Therefore you'd use
                  which acts like a 'wildcard' and every component containing the text 'Component#' will have that replaced with 'Dice' ??????
                  So 'Component#1 >>> 'Dice1', 'Component#2 >>> 'Dice2' etc
                  As I then explained further you can constrain the renaming to a smaller set by using other pattern matching like [1238] to just process the first three and the eighth one
                  renameDefinitions 'Component#[1238]', 'Dice#1'
                  to rename them all first as as 'Dice#1', 'Dice#2' etc and then in a second step using
                  to rename them all as as 'Dice1', 'Dice2' etc...
                  This does NOT work on a highlighted 'selection' !!
                  You make your selection using a pattern matching string in the name!!!! πŸ€“
                    So there is no possibility to change 2 objects components Definition named
                    Ball
                    Poll
                    to these Definition named Dice1, Dice2 in one pass?
                      No...
                        Finally i have found a trick with another Console Script of your! πŸ‘
                        I explode all components selected and call your tricky thing who tranform any selections in Components! 😎
                        m=Sketchup.active_model;  ### tranform any selections in Components By TIG
                        m.start_operation("Faces>Compos");
                        n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
                        g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
                        m.commit_operation
                        So obtain a generic Components' name: FaceSet#1, FaceSet#2 etc...
                        Call your renameInstances many posts above
                        So obtain an only one name for all the Components: FaceSet#
                        So I can use it inside the Plug Random Replace Component
                        and even now no kneed to change it in Dice! πŸ˜’
                        ...but I must change my tutorial! πŸ’š
                        Thanks again for your lessons! πŸ‘
                        I have seen many things about renaming but see also that I am definitly not made for ruby scripting! πŸ˜’
                          and...In fact that is some redundant with the use of the Dialog box Info for rename a group of components! 😳
                          I had an headache for a so simple solution πŸ˜„
                            My trick works only with components with no level of component inside πŸ˜’
                            and for rename a same component with definition name "Ball" existing in different positions
                            as new components with of course new definitions name Ball1, Ball2, Ball3 etc... ?
                            I suppose they must be "Make Unic" then renamed
