    Scenes
    9 Posts 5 Posters 468 Views 5 Watching
      dallen
      While Creating Scenes, I am attempting to view the plan view of a roof plane. Is there a way to select the face of a roof and view it as the flat plane?
      • ToboboT Offline
        Tobobo
        Under the 'View' menu there is a option called Paralell projection. try that
        Toby
        Philippians 4:13
          Could you give more detail as to what your roof looks like?
          There's a standard Top view that you can select. You could also select a face, right click and choose Align View. As Toby mentions, you can set the camera to Parallel Projection if needed.
          • K Offline
            KarinaGM
            And once you are in parallel view you can right click on a face and "Align View"
            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
            -Benjamín Franklin.**
              dallen
              There's a standard Top view that you can select. You could also select a face, right click and choose Align View. As Toby mentions, you can st the camera to Parallel Projection if needed.
              Align View did the trick, Thanks.
              There will be less questions as I continue to learn.
                Do I hear an echo? 😆
                Darren, no worries on asking questions. That's a big part of keeping this place going.
                • boofredlayB Offline
                  boofredlay
                  Right click on the roof plane and choose "Align View".
                    • K Offline
                      KarinaGM
                      Good one 😛
                      Dave. Oops.... 😳
                      Didn't noticed you answered before. You were faster typing, because I'm sure your post wasn't there when I wrote mine.
