    How to do "ringcuts" (kind of)?
    12 Posts 9 Posters 940 Views 9 Watching
      SurfingAlien
      Hi!
      I'm afraid this will be an "oh..." question after seeing your replies but I can't seem to figure it out myself...
      is it possible to do (kind of) ringcuts on a circular/conic shape like the one in the attached screen shot?
      sorry, hardcore box/subd modeler here...
      I tried with Fredo's bevel/round corners tool but it produces unexpected results for the central ring (while it uses to work flawlessly in standard beveling tasks like the top and the bottom)
      thank you in advance for any advice
      Alessandro
      • ToboboT Offline
        Tobobo
        I would use a filled circle. Copy it down to the height you want and the intersect the circles with the model.
        Toby
        Philippians 4:13
          Select the largest topmost circle.
          Copy it vertically downward with Move+Ctrl, using shift/arrow-key press to constrain in blue-axis so its where you want the 'ringcut' line.
          Make the copy a group [this is so it doesn't interfere with other geometry accidentally].
          Edit that group and overdraw a piece of segment to make a face.
          Exit the edit session and copy the group vertically downward with Move+Ctrl, using shift/arrow-key press to constrain in blue-axis so its where you want the next 'ringcut' line.
          Repeat this as many times as you want 'ringcuts'
          Select the groups and the original curved surface[s] and right-click context-menu to intersect with selection.
          Erase the now unneeded groups.
          The original surface[s] should now have your desired 'ringcuts' inscribed on them...
          I used the top circle copy and added a face etc as it was conveniently bigger that what we needed... BUT you could just as easily drawn a new large faced rectangle slicing through the form about where you wanted the 'ringcut', grouped it and then done the move/copy etc as above to form the intersection marks... Note if you don't group the temporary intersecting face it will get an inner face split off during the intersection processing and it'll be awkward to erase it later - however there are times when you might want this new inner face to form too 😕
            d12dozr
            There's also the Knife tool if you have Artisan/Subdivide and Smooth...
            http://goo.gl/f7ooYh
              SurfingAlien
              thank you Tobobo and TIG!
              that worked. actually, I cannot say why it didn't worked before (it's the first thing I tried...).
              I probably screwed up something... (it's a component inside a group inside...)
              cheers,
              Alessandro
                Seems this tool can help you 😉
                TGI3D
                Seems it's free for this tool ☀
                [flash=425,349:p9685o5n]http://www.youtube.com/v/11mhfNJlduE?version=3&amp[/flash:p9685o5n]
                  driven
                  I often use a section plane to get a better look, turn on hidden geometry, draw a rectangle, add detail, turn off hidden geom, delete the face and bits I don't want, select a curve and use follow me to add to the model.
                  I'm not sure what your 'ring cuts' look like, here's some pics of my technique... john
                  • jeff hammondJ Offline
                    jeff hammond
                    fwiw, a few more plugins that you could do this with: (if you're interested in going that route)
                    tools on surface -- offset
                    1001bit -- slice face horizontally
                    zorro2
                    dotdotdot
                    • mitcorbM Offline
                      mitcorb
                      Does this have any relevance?:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=37520
                      Just a few posts away in "Active Topics"
                        SurfingAlien
                        thanks for all the additional suggestions,
                        artisan (and eventually tgi3d) is something I'm consider to buy if I get more serious about SU modeling (I'm using a bunch of modeling tools atm).
                        1001bit... oh, well I own that one but I forgot it has that feature too 😞
                        the "lathe" approach is something I used in the past but this time I was looking for a way to quickly adjust an existing component
                        great community... 😉
                        cheers,
                        Alessandro
                        • G Offline
                          gulcanocali
                          Hi Alessandro,
                          @surfingalien said:
                          artisan (and eventually tgi3d) is something I'm consider to buy...
                          Just FYI, cross section tool mentioned here is available unrestricted in the free Training Edition of Tgi3D SU Amorph.
                          Regards,
                          Gulcan Ocali
                          Product Manager
                          http://www.Tgi3D.com
                            SurfingAlien
                            @gulcanocali said:
                            Hi Alessandro,
                            @surfingalien said:
                            artisan (and eventually tgi3d) is something I'm considerING (ouch!) to buy...
                            Regards,
                            thank you for the info,
                            I saw it was available in the free training edition (as pilou pointed out)
                            it was a more general thought about some very well done tools
                            I'm doing all the "organic" modeling outside SU at the moment (Silo3D and Cheetah3D mainly)
                            cheers,
                            Alessandro
